Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
New SVC 1 Piece UCA's
This is a discussion on New SVC 1 Piece UCA's within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Introducing our new 1 piece UCA for the Ford SVT Raptor. First let us answer one question before it's asked. ...
Like Tree20Likes
Sponsored By: Fox - Redefining Ride Dynamics
Old 01-29-2015, 06:16 PM   #1 (permalink)
svc's Avatar
svc
Default New SVC 1 Piece UCA's
Introducing our new 1 piece UCA for the Ford SVT Raptor. First let us answer one question before it's asked. No, we will not be discontinuing our 2 Piece UCA. As of today, we have raised the price for the 2 piece UCA to $1100 do to the labor intensive production cost to produce those arms. This decision led us to create the new SVC 1 Piece UCA at the same price point as the original 2 piece. It was important to us that we made sure to have an arm that was still under the thousand dollar price point range.
So with that said, here's the skinny on the new arm
We are all about variety at SVC. This philosophy has led us to develop our new 1 piece 1.5" Upper Control for the SVT Ford Raptor. Much like everything we do, these arms fit and finish are second to none and made from the same materials, and designed in the same fashion that you will find on $500,000 race-trucks. We carried over much of the same hardware from our Raptor industry first Two Piece UCA and wrapped it into one clean and usable package.
When it comes to a UCA, strength of components is the name of the game, and we are proud to say in over 1 year of hard off-road abuse, neither we, or any one of our customers has seen one component failure or broken center pin. Our arms have been at every one of the Raptor held events, including Raptor Expeditions tortuous runs down in Baja Mexico. Our One Piece UCA features the same 3/4in 12-point 8740 aircraft grade bolt as our Two Piece UCA, the same 7/8th FK rod-ends vs. the more commonly found 3/4in rod-ends in other similarly designed arms, plus we use only grade 8 chassis side hardware for added insurance. The spacer are CNC Machined for a precise fit which equates to a long lasting and esthetically pleasing part
During the construction phase, the arm is jig welded and keyed for better fitment. The arm itself is on two different planes to ensure the bearing cup is at the proper angle and not rotated in the arm. This allows for a better weld joint at the most critical part of the arm because there is zero gaps that need to be filled with weld material. The arm is fully camber caster adjustable which allows you to solid mount the problematic lower control arm pivots from shifting and constantly throwing your truck out of alignment.
Bottom line, no other arm in this price range give you more for your money
If your ready to make the switch or upgrade your UCA for the first time, don't hesitate to call or click here to order. http://www.svcoffroad.com/suspension...er-control-arm
Thanks for looking
Jarrett
SVCOFFROAD
Monday-Friday 9-5pm
1-888-976-5588
27324 Camino Capistrano Unit 181/227
Laguna Niguel,CA 92677
[email protected]
https://www.facebook.com/specialvehicleconcepts
http://instagram.com/officialSVC
https://twitter.com/officialSVC
svc is offline   Reply With Quote
Old 01-29-2015, 07:06 PM   #2 (permalink)
RDFTS's Avatar
aka Rick
Will these work with stock wheels and tires??
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR 14'/15'/16'/17' | Raptoberfest 14'/15'/16'/17' | Time Attack 14' | Snoball 15'/18' | AR Run 15' | TRR Baja 16' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 01-29-2015, 07:07 PM   #3 (permalink)
Yukon Joe's Avatar
Sexy.....
I think the number 1 question will be; will these work with the stock beadlock wheels?
Thank You for your donations to Avery. We hit our goal!
Yukon Joe
Snoball 3
Delta Lead
www.runraptorrun.com
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 01-29-2015, 07:09 PM   #4 (permalink)
svc's Avatar
svc
Originally Posted by Yukon Joe View Post
Sexy.....
Yukon Joe
Snoball 3
Delta Lead
Run Raptor Run | Great Lakes Raptor Excursions (GLRE)
Not yet Joe, We will be releasing the 1" version in about 5-6 weeks that will work with the stock wheels. It will be same design just smaller cup.
Jarrett
SVCOFFROAD
Monday-Friday 9-5pm
1-888-976-5588
[email protected]
Old 01-29-2015, 07:14 PM   #5 (permalink)
Jimbo's Avatar
Mad Frog Mattis
Jarrett
@RDFTS upper control arm issue solved in 5-6 weeks!
SECDEF OF THE MEME CORPS
Jimbo is offline   Reply With Quote
Old 01-29-2015, 07:17 PM   #6 (permalink)
RDFTS's Avatar
aka Rick
Jarrett
Will the adjustable UCA ever be made in the 1" version to work on stock?
Old 01-29-2015, 08:49 PM   #7 (permalink)
svc's Avatar
svc
Not sure yet. As of right now only the 1 piece is slated to get the 1.0 bearing cup.
Jarrett
MTUH3 likes this.
SVCOFFROAD
Monday-Friday 9-5pm
1-888-976-5588
[email protected]
Old 01-29-2015, 09:11 PM   #8 (permalink)
Jimbo's Avatar
Mad Frog Mattis
R&D a set for Rick and he'll test them at TRR for you.
Old 01-29-2015, 09:17 PM   #9 (permalink)
Raptizzle's Avatar
FYT
Saw these arms in person yesterday and can attest to the quality. The TIG welds are nothing short of perfection and the overall design is badass.
INI and FnDynamics like this.
Gen 2 Raptor Equipped With:
SVC Offroad
KING Race Shocks
DEAVER Suspension
Raptizzle is offline   Reply With Quote
Old 01-31-2015, 07:59 PM   #10 (permalink)
svc's Avatar
svc
Here you go. The 1" will be going to laser cut at the end of next week. Stock wheels will be a go with this arm
Jarrett
FnDynamics likes this.
SVCOFFROAD
Monday-Friday 9-5pm
1-888-976-5588
[email protected]
Tags
special vehicle concepts, suspension, svc, uca
NEED FRONT VALANCE piece Amarr014 Want to Buy 14 09-05-2014 03:09 AM
1 piece rear window Mike McG Ford Raptor Exterior Modifications Forum [GEN 1] 14 11-11-2013 11:59 AM
New bumper piece Hockster Ford Raptor Exterior Modifications Forum [GEN 1] 39 12-21-2011 06:58 PM
Front bumper piece RaptorRed Ford SVT Raptor General Discussions [GEN 1] 6 09-18-2011 12:12 AM
