Been working on this one for the last couple months. Wanted to post up some pics of it. Testing is done and final install will be next week- just making everything look pretty.
Modular design- can be used as dual with jack mount in the middle ect or triple stand up OR single lay down with out the removable center bars- fits under covers this way
Bolts into 4 front factory bed bolts and additional holes are drilled in the rear
Built from 1 3/4 dom tube
With everything removed 95% of the bed can be used
This prototype uses cantilever shock set up incorporated relocating shocks into the bed. 16 in of travel from the stock length 12 travel shock. Links pass through a small hole in the wheel well. Frame connectors are used to reinforce everything
New lever set up with bearing/race- no more bushings to wear out
This cage will be offered with or without cantilever shock set up. Traditional long travel with shocks mounted forward will also be an option.
More pics next week
More pics next week
