64auto
Looking to do Mid perch but don't trust anyone locally with my truck. I am taking a road trip to Memphis TN This weekend. Does anyone know someone around that area that does it and can be trusted
Why did you drop the A arm?I did mine last Wed. took me an hour to do one side and 15 minutes to do the other. I didn't remove anything but the tire on the second side. Just compressed the spring with Jack, tightened the spring with spring compressor I borrowed from auto zone, drooped out the a arm, moved to mid perch, then took it to the alignment shop. Guy said the alignment was out. 002". Real easy mod.
Sent from my Nexus 6 using Tapatalk
Going to jump on your thread. I put on R1 rotors yesterday and decided since the front was on stands I would try to go to mid perch. I tried using my heavy duty spring compressors but the tabs were to long to fit in and even if they could the U bolt that holds the springs was to small in diameter.. I went and bought the smaller claw looking compressors and went to work. After 2 hours of the F:king compressors slipping off I finally got them compressed enough to see the set screw and that was it. The washers bound up and I couldn't get the springs any more compressed. The last hour I gave up. Put everything back and quit. WHO MAKES A SPRING COMPRESSOR that fits and will hold and is strong enough to compress our springs? I am not a novice but this is the first time I ever quit and gave up on a mod. I was an inch away. Unless you have the right compressor don't start this mod. Everything else was easy. I even got the set screw loose and the collar to move up enough to see the c ring. Just not far enough.
---------- Post added at 06:01 PM ---------- Previous post was at 05:58 PM ----------
Why is it safer removing the strut?It's not hard at all to remove the struts. With the strut off the truck, it makes it easier and safer to compress the spring. You can also clean it while it's off.
You want to get a McPherson Strut compressor, not a coil spring compressor.
You can space the compressors 180° out from each other while they're still on the truck so I still don't follow. I would think that as a bonus even if they did slip having them mounted would be the safer place for them to be in the event of a failure? Always open to being learned but I'm just not following the logic unless you're taking them off and doing it with a press.Because you can get the compressors evenly spaced and compress the spring further than if you were trying to compress the spring from the open side of the shock mount housing. If you don't compress them evenly you have a greater chance that the compressor will slip off.
