Lower control arms
YAMAHATOO
Any aftermarket suggestions? can I just replace the stock ball joints or should I look to replace the LCA whole assembly?
Mluis11
You can replace the lower ball joints. No functional benefit in going aftermarket unless you're looking to add a bypass shock.
Baja Kits
Newport Beach, CA
This right here!
If you do decide to run a secondary bypass, we can get you taken care of with our LCA!
Y
YAMAHATOO
Check with Rockauto for replacement ball joints. They also offer a forum discount.
COOL, wondering if should do the aftermarket LCA while iam at it although I just did moog UCA back in December what do you guys think , as there are a a lot of options on aftermarket CA and iam not planning on running in the baja 1000 anytime either lol
