[/COLOR]
Not to clutter up the other two threads (the train wreck and on topic thread)
Why is everyone talking about long travel?
Why spent $6000 and up for only a couple of inches of travel?
If your are traveling fast enough to need long travel, you are going fast enough for a roll cage.
Rear of the Raptor has always been "weak link". So upgrading the front without upgrading the rear is asking for damage.
At this point wouldn't it be cheaper just to cage, four link the rear and do it right in the first place?
If I am wrong in my logic please let me know..
-Greg
Glad this was started... Here is my statement that I added in the other thread..
This might not be the correct thread for this discussion... But IMO long travel suspension is not really needed for the masses... There are a lot more things to take into account if you are planning on adding long travel because you are drawn to the foot and a half wheel travel numbers. IMO the long travel suspension is just a single part of a complete build needed to have a good performing and safe truck.
I have talked a lot, and I mean a lot of people out of a long travel kit for their Raptor and into something that is much more suited to what they actually want to accomplish with their truck. It truly isn't about the wheel travel numbers, but rather the entire set up of the truck. You can spend the same money you were going to spend on just the long travel parts and have a well balanced truck that will perform.
You should figure not only the cost of the LT but a few other items to go with it..
Front -
LT kit
Coil overs
Bypass shocks
Bumps
Axles or complete RCV asy
Fiberglass
Professional install
Rear-
At the minimum-
Deavers
3" bypass
bump set up
Our set up will gain you 1.5" of travel and more wheel control
Better-
Sprung under
3" bypass
bumps
bed cage or cantilever design
Our set up will net you up to 17.5" of travel and more wheel control
bedsides
professional installation
More-
Dana 80 rear end
Engine cage
Complete interior cage
4 link
Figure it is easy to wrap up 30k - 150k+ into a built raptor... Not including the price of the Raptor... Imagination, know how and your pocketbook will take you there...
