Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
Installing shrader valve in stock 2.5 internal bypass svt shocks
This is a discussion on Installing shrader valve in stock 2.5 internal bypass svt shocks within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Well done man, about time ya tackled it.... not as big a deal now looking back right??? L8tr Oh and ...
Like Tree8Likes
Sponsored By: Fox - Redefining Ride Dynamics
Old 12-20-2014, 11:20 AM   #11 (permalink)
onesickpuppy's Avatar
Oh and I used lock tite for tread seal... :)
---------- Post added at 07:20 AM ---------- Previous post was at 07:14 AM ----------
Originally Posted by loki_13 View Post
Has anyone tried different psi charges in the stock shocks yet?
Shock pressure on the actual shock has little effect that you would notice. It is mainly there for keeping the oil from foaming up. If you have air bumps they can be adjusted a bit with lower and higher pressure for slight spring rate change for the bump.
Mods: Mid perch with Farrar Racing tuned position sensitive by-pass shock mods, Sway bar delete, custom MFT back screens, IC-706MlKll installed, Spot connect, HF, VHF& UHF antenna installed, duplexer, PCI intercom with street legal head phones and helmets, Raptor claws with D2's, 30" curved behind grill light bar Outlaw/Fox bump stops, Deaver +2's W/ 1" block, bed rack powder coated fender flair color, with 2 factory beadlock wheels and BFG's Lowrance HDS-5M, VIM
onesickpuppy is offline   Reply With Quote
Old 12-20-2014, 11:42 AM   #12 (permalink)
Junior Member
Thanks, not bad at all. I actually did the ones on the front of my blazer last summer. Did these ones for the rear last night.
You had info on some tuning with these didn't you?
onesickpuppy likes this.
Deuling is offline   Reply With Quote
Old 02-08-2015, 05:19 PM   #13 (permalink)
Okay don't habe understand why, but what can i do after installing this valve? Do i have than a way to make the suspension more comfortable by adjust the pressure? Read some more Treads about that and now i know that i can adjust the pressure inside the shocks. Do any of you know how to make the stock Fox more comfortable?
Daniel
nbg-mustang is offline   Reply With Quote
Old 02-08-2015, 06:03 PM   #14 (permalink)
cups's Avatar
Alittle boy butter might make it better.
cups is offline   Reply With Quote
Old 02-08-2015, 09:34 PM   #15 (permalink)
Junior Member
Daniel
On a stock raptor that is a dd/weekend warrior? Nothing and don't waste your time.
If your into modifying and making stuff work better offroad.... Then shraders are way easier to put nitrogen back into the shocks after tearing them down and changing valving etc. The stock setup requires a goofy needle fill valve that I personally do not like, and is just one other tool to keep track of. Also my fox 2.0 bump stops have shraders on them, so why not just have one fill tool.
My shocks arent really raptor related though.... I just like you guys for the shocks you get rid of, so just keep upgrading to better shocks and selling your oems to people that cant afford a raptor like me ;)
KaiserM715 likes this.
Old 02-15-2015, 04:42 PM   #16 (permalink)
The Raptor is a non daily driver daily driver car. Take it to pul, trailer or any other work think's.
But i think that the suspension is not good for trailer and/or street comfort. These two points i will fix, Raptor need more comfort in this two situation. I was hope that i can bring more comfort to the suspension to update valve and than set the pressure higher or lower.
Thanks
Daniel
Tags
2.5, piggyback, rebuild, shocks, svt
UPGRADE - 3.0 Internal Bypass Coil-Over FOX FOX Racing Shox 27 10-17-2013 06:04 PM
ICON 3.0 Bypass Shocks in Action.... ICONRep ICON Vehicle Dynamics 1 12-11-2012 02:46 PM
Fox 3.0's Internal Bypass now in stock RPG RPG Offroad 23 07-22-2012 08:13 PM
WTB: SCrew Take off stock shocks treypal Want to Buy 10 05-04-2012 05:02 PM
Icon bypass shocks being built for SDHQ SDHQJASON SDHQ Offroad Racing 8 03-22-2012 12:24 PM
