Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
ICON Vehicle Dynamics - Ford Raptor RXT Rear Suspension System
This is a discussion on ICON Vehicle Dynamics - Ford Raptor RXT Rear Suspension System within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Originally Posted by never_summer With the rxt rear suspension and 37's should the rear pinch weld need to be cut/rolled? ...
Like Tree53Likes
Sponsored By: Fox - Redefining Ride Dynamics
Old 09-07-2015, 10:27 PM   #61 (permalink)
RDFTS's Avatar
aka Rick
This was asked and answered earlier in the thread.
Is there any interference with over axle exhausts with the up travel?
Having just had this installed, I would say that most exhaust are going to be very tight going through the top support and tension bar. If you did get it through, I would imagine that it's going to hit. I ended up having to put turndowns before the axle. When I called ICON, they told me the same thing.
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR 14'/15'/16'/17' | Raptoberfest 14'/15'/16'/17' | Time Attack 14' | Snoball 15'/18' | AR Run 15' | TRR Baja 16' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 09-09-2015, 08:46 PM   #62 (permalink)
RDFTS's Avatar
aka Rick
Default ICON Vehicle Dynamics - Ford Raptor RXT Rear Suspension System
Question now that I have the RXT system installed:
1. The center bolts on the leaf spring were not trimmed off as according to the instructions. How critical is that? It seems a tad more difficult now with the u-bolts in the way. They did the add-a-leaf so there isn't much thread past the top of the u-bolts. Wasn't sure how tight the clearance specs were because I would think if the bolts ends would hit then why wouldn't the u-bolts be hitting anyways? Also note that I have Camburg 1.5" shackles.
2. Does the bumpstop parts that wrap around the frame go flush together on the top and bottom? On the driver side, there is about a 1/4" gap or so there where it does not meet on the top (bottom is flush). Is that common? Will it cause an issue as long as the bolts are torqued?
Thanks!
@ICONRep
Tags
icon, leafspring, raptor, rxt, shocks
ICON Vehicle Dynamics Ford Raptor Front 3.0 Secondary Bypass Shocks ICONRep ICON Vehicle Dynamics 11 07-21-2014 01:29 PM
All new look of the ICON Vehicle Dynamics Raptor ICONRep ICON Vehicle Dynamics 52 06-09-2014 10:46 AM
Icon Vehicle Dynamics Ford Raptor Suspension Outlaw Offroad Outlaw Offroad 7 12-07-2011 04:26 PM
