ICON Vehicle Dynamics - Ford Raptor RXT Rear Suspension System
MOLONxLABE
NE Colorado / Lake Havasu City, AZ
@ICONRep
I'm running a Deaver +2 leaf pack with your bump stop kit. Can I remove the bump stop spacer for the up travel gains or is that a bad idea?
---------- Post added at 03:22 PM ---------- Previous post was at 03:15 PM ----------
I should I also add that I'm installing a traditional bed cage suspension setup soon so the shock won't be a limiting factor.
My question is will my leaf pack strike the bump stop frame at full bump?
ICONRep
ICONRep
Riverside, CA
@ICONRep
As long as the specific Deaver pack you are running is not to think then there should not be an issue. The Deaver +2 should be fine with out coming in contact, but we have not tested in house at this point. With that said......You need to have whomever performing the work cycle the suspension, and come up with those answers 100% on your truck with all parts being used factored in.
MOLONxLABE
Okay, that's what I thought. Thanks for the insight, I'll stop hijacking your thread now lol.
Hockster
My 45ft Bluewater Party
Winchester, Va
Is there a need to change the location of the brake lines and abs wires to allow this extra movement?
Nick@Apollo-Optics
How much disassembly/assembly is required to adjust the leaf springs? I tow with my truck from time to time and want to be able to tow when I need to, but not have the extra lift for daily driving and parking garages.
