How to build
Virginia
I have been testing the raptor and I want to have better feeling and less rattling/shaking while off road, I don't want to crush the bank but I need options/ mods to give it a better more capable feel off road, especially for the rear! Have a stock suspension and mid perch is pending!
Thanks
BK
Raven13
College Station, TX
Deavers for the rear make a very noticeable difference. I also have Geiser springs up front and they are an improvement. I would start with Deavers first, the stock back end can't keep up with the front. Also would recommend a bumpstop kit if you don't have one already.
2014RubyRed
Galesburg, IL
Mid perch with Deavers will help a bunch. Also, if you're ready, purchasing some 3.0 shocks with adjustability will do the trick. Icon, Fox, King all have adjustable shocks. The Icons I had had several settings on a knob that you could simply turn. Turn them to "1" for normal road use, then crank them up to "8" for off roading. Really made a big difference in how the rear of the truck handled the rougher surfaces......
schmeal
Reno, NV
What psi are you running on the trail? Airing down more really helps with the chop.
Big Country BK
Virginia
Thanks for all the insight! I'm hoping to sell my motorcycle and get the rpg stage 3, or start with stage 2 and then upgrade to deavers when I get the cash! @2014RubyRed I would love to spend it and get 3.0s the knob adjustable sounds awesome. I just run standard psi what would you bring it down to? I mostly run gravel& dirt/wooded trails no sand near me hear in the mountains @schmeal
t_j
Chicago, IL
+1 on the rear leafs.
Depends on the trail, dropping to 30psi will cut a lot of chop on the gravel type roads. Go lower for rougher trails.
schmeal
Reno, NV
@Big Country BK I'm usually at around 25 psi during runs. This is something you can play around with and see what works best for you. I'd start with coming down a little at a time, see how it feels then go from there.
2014RubyRed
Galesburg, IL
You know, I only aired-down once the entire time I off roaded. That was in the mountains and I went down to like 30 psi. Other than that, I ran the psi at 40 all the time. Like you, I only ran a few times in the sand, so didn't experience that.
Let me know when you're ready to do the upgrades. I can help point you in the right direction......
