Finished up the new designs for the Gen 1 LCA support kit. There are 2 options for the front pockets----- 1 is a basic plate slot eliminator and the other is a pocket trim style which we have used for a while.
The rear lower pockets bend VERY easily - I have repaired a bunch--- The rear support bracket helps strengthen the pocket.
We also have locked the lower control arms to the outer most position. Adjustable UCAs are needed with this set up.
Kit is priced at $299 with either option and includes all hardware. If you choose the front pocket trim option it will need to be welded in. All other brackets can be bolted in.
