Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
Geiser Progressive Spring Review
This is a discussion on Geiser Progressive Spring Review within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Like Tree2Likes
Sponsored By: Fox - Redefining Ride Dynamics
Old 08-10-2018, 09:03 AM   #11 (permalink)
Raven13's Avatar
On mid perch the Geiser springs will ride a little stiffer than stock, less nose dive while hard braking, firmer feel on corners. Off road they feel softer, kind of like going to Deavers in the rear felt like. IMO they are worth the cost, not 3.0ís but definitely better than stock.
Raven13 is offline   Reply With Quote
Old 08-10-2018, 09:28 AM   #12 (permalink)
stewwalker's Avatar
How much stiffer and do they eliminate the felt chatter/shudder that stock springs give you?
stewwalker is offline   Reply With Quote
Old 08-10-2018, 11:22 PM   #13 (permalink)
stewwalker's Avatar
After some more thought, research and beer, I think I have this progressive spring thing figured out and can answer some of my own questions.
How are Geiser springs stiffer?
When at ride height and under the weight of the truck, Geiser springs will be into a “stiff zone” equal to the weight of the truck. I assume that Geiser spring rate at ride height is stiffer than stock to improve bottoming resistance.
How are they more compliant over small bumps?
When you hit a bump with stock springs, the amount of force input to move the shock X inches up, is also the same amount of output force for the shock to return to its normal position. As I stated before, think of a linear graph for both compression and rebound.
When you hit a bump with Geiser springs, the amount of force needed to move X inches will not be linear. Think, of a progressive graph. So if you take a jump and all 4 are off the ground, instead of landing on a 550 lb spring then a 1100 spring then a 2200 spring, you would be landing on a softer spring, then a little firmer spring, then a firmer, so on and so forth.
To me the benefits of progressive shocks will be most noticeable if you are working the shocks and utilizing the full stroke because you would be getting a softer spring rate when they are fully extended, and a stiffer spring rate when they are fully compressed.
This might be obvious to some, but I’ve finally been able to wrap my head around what to expect out of these springs. Waiting to hear a good review, but I think I’m on board.
I am not an engineer, I am not an expert, I am probably wrong.
Old 08-11-2018, 06:52 PM   #14 (permalink)
Raven13's Avatar
Just a bit stiffer, not harsh IMO. I don’t think shutter is completely eliminated but is lessened, again I had mine at midperch. And you are correct, the biggest felt difference will be when your using the full shock stroke such as when off-roading. They give a much softer ride off-road than the stock springs do.
Old 08-11-2018, 09:26 PM   #15 (permalink)
stewwalker's Avatar
Just a bit stiffer, not harsh IMO. I donít think shutter is completely eliminated but is lessened, again I had mine at midperch. And you are correct, the biggest felt difference will be when your using the full shock stroke such as when off-roading. They give a much softer ride off-road than the stock springs do.
Interesting. I actually liked the off road feel of stock springs on mid perch, but the day to day driving was horrid. Lots of shoddy patch and seal in Houston, I would prefer dirt roads.
Old 08-11-2018, 10:21 PM   #16 (permalink)
J DAMAGE's Avatar
Just installed the Geiser springs, and new Fox 2.5's set on bottom perch, been 1 week since install, and I can't get over how much of a difference there is from stock springs just with on road manners, my original set up was mid perch on 2.5's... First thing I noticed was no more bump steer, then when driving on bad and uneven roads the small hits don't transmit to the steering wheel any more, my truck is my DD, and 95% on road. Now driving you can really see and feel how the back end of the truck sucks, with the back end kicking in certain conditions, now I see and understand with this small mod what others have stated, the front out drives the rear, there not kidding, next step for me is deaver +3 with shackles and bump stops, onec i find a sweet deal on them.
I came very close to pulling the trigger on 3.0's, but changed my mind, not because it was more suspension than I need, but watching then get murdered from the winters and road salt here in jersey, would of broke my heart to see awesome shocks killed buy weather and salt, over being used as they were designed for.
NOTE# I degassed the new shocks, and added schrader valves, recharged to 200psi, the factory nitrogen pellets suck and fail faster than they should causing shock failure.
J DAMAGE is offline   Reply With Quote
Old 08-13-2018, 09:48 PM   #17 (permalink)
stewwalker's Avatar
Originally Posted by J DAMAGE View Post
Just installed the Geiser springs, and new Fox 2.5's set on bottom perch, been 1 week since install, and I can't get over how much of a difference there is from stock springs just with on road manners, my original set up was mid perch on 2.5's... First thing I noticed was no more bump steer, then when driving on bad and uneven roads the small hits don't transmit to the steering wheel any more, my truck is my DD, and 95% on road. Now driving you can really see and feel how the back end of the truck sucks, with the back end kicking in certain conditions, so i can say that the others that say with this small mod, the front out drives the rear, there not kidding, next step for me is deaver +3 with shackles and bump stops, onec i find a sweet deal on them.
Glad to hear good things. I'll probably follow your path in a month or so after it could down enough to work outside.
How To Geiser Brothers Progressive Coil Installation bigrig Ford Raptor How-To's and FAQs 16 04-10-2018 01:40 PM
Geiser Bro's Raptor Progressive Springs Qcfx2 Garage Sale 549 03-13-2018 10:48 PM
Geiser Progressive Coil Springs Sitdown Garage Sale 7 05-20-2016 10:58 PM
WTB Geiser progressive front springs Krow Want to Buy 1 01-28-2015 08:39 AM
