PGLMike
I am having a tough time installing the shock on the front passenger side. Driver side wasn't too bad. I disconnected the sway bar, tie rod and spindle, got the stock shock of out with no problem. But installing the new to me replacement with Geiser spring was a whole different story. The bottom eyelet would not line up in the lower control arm. It is only off by 15 degrees or at least that is what it looks like. So, I tried putting the bolt in and turning it, no luck. Tried turning it with a breaker bar, no luck. I ran out of time and had to leave the truck on the jack stand tonight. I am going to try and put on the McPherson Strut compressor and see if taking the tension off of the coil will allow me to spin the bottom of the shock to line up in the pocket in the lower control arm.
Anyone have any advice?
