Fox QAB Knobs (Quick adjusting bypass)
ISFast
Tulsa, OK
Was hoping for some more information about these. Can we buy them to put on our 3.0 fox rear bypass shocks and if so could you do it without having to pull the valve out of the bypass. Don't want to open up the shock if i don't have too.
Anyways looks like something I might use due to stock rear suspension other than the 3.0 and down the road a stage 3 will be added. But until then adjusting before, after, and even with some weight in the bed might be a good thing.
Thoughts and some help would be great. Just saw them on the dual front end and really didnt know much about them but was wondering why they didn't have them to begin with or was it because of a corrosion issue as far as trapping salt?
Ford Raptor Shock - 3.0 Factory Series Bypass QAB Reservoir Bypass Shock | FOX
MotuMute
Dallas, TX
Apparently there are a lot more questions than answers at the moment Alan... I have a few myself
FOX
El Cajon, CA
The Quick Adjusting Bypass (QAB) technology is available as an upgrade for 3.0 FOX External Bypass shocks.
FOX QAB Upgrade Kit
QAB Blue Compression Kit 815-03-010 $80.00 each retail
QAB Red Rebound Kit 815-03-011 $80.00 each retail
For complete product details visit: http://www.ridefox.com/upgrades
View complete New Product Bulletin HERE
---------- Post added at 01:31 PM ---------- Previous post was at 01:27 PM ----------
To install the QAB requires removing of the existing bypass check valve hardware. To remove this hardware the oil will need to be drained and then bled after refilling.
ISFast
ISFast
Tulsa, OK
Thanks I'll take a look. Glad to know these will work with what I already have.
