Sage
OK, I've run them for 6 months++. They worked great for towing and with a heavy load in the box.
I did not like the fact that I needed air to keep them off the internal bump stops. I removed the bags to get my stock ride back for now. I did not remove the bottom mount and I think I could spend a little time to modify the upper mount and it could also stay on. I had to remove it to put the factory bumps back on.
If the top mount was modified, it would only be a 15 min job to put on or remove the bags. 3 bolts and a short air line per side. The upper mount is very heavy and should easily replace the light duty frame kit I had on before.
I will put them back on next spring when I'm towing again... then back off !! I will be moding the top mount and possibly leaving the factory bump on with it.
