F150 Rear spring
Glex25
I'm doing a full Raptor conversion on my 2011 F150 XLT 4x4 and I'm seeing threads here where people have added a leaf to their rear suspension for additional payload support.
If I were to keep my current oem leaf spring and just install the Raptor shackle, Block, U-bolt and shock would there be any issues with this configuration?
AndysLog
Moro IL
i dont believe so. you may need to make sure brake lines and abs stuff is all extended for the travel.
G
Glex25
I just installed the raptor block and u bolts on my 2011 XLT and it worked just fine. No need to switch shackles or leafs.
Cool thanks.
I'm still looking for a Rear block and just need to purchase the different U bolts.
I do know the brake line and the vacuum line for IWE will need to be longer in the front. I don't believe the rear needs anything as far brake lines or vacuum.
