GEN 1 Camburg Kinetik vs Icon Delta Joint Billet UCAs
JtoU
I bought Camburg Kinetik uca's and i had binding problems with them. I do have Camburg uprights, svc lower and it will not work with these. I can't say does it work with different brand parts. Sdhq said that they have not have any issues installing these to Gen 1 tho.
I bought new Icon uca's and no problem what so ever. They have changed design a bit and with new Delta joint it's great product.
Deleted member 12951
Desertrat83
So Cal/ Arizona
I cant speak on the Camburg stuff. I have the Icon setup and the selling point for me was the fact that the Icons allowed adjustment for alignment without removing any hardware.
Been 6 months so far and have had zero issues.
Icon_Adrian
Riverside CA
Does anyone have any experience with the icon delta joint?
I'm looking at replacing my spherical bearings out for these.
@Yukon Joe
If you pull the trigger here is info regarding part numbers.
Icon UCA:
http://iconvehicledynamics.com/shop/delta-joint/1245-2004-up-ford-f150-delta-joint-retrofit-kit.html
Non-Icon UCA:
http://iconvehicledynamics.com/shop...0-non-icon-uca-1-retrofit-deltajoint-kit.html
Feel free to reach out if you have any questions or concerns.
NEOGARAGE
North Royalton, Ohio
Both are amazing products.
If it were me, I’d honestly go with the Icon DJs just because it’s less maintenance, you sacrifice zero performance and it’ll last much longer than an open unsealed uniball.
The icon UCAs are also easier to adjust for alignments as well.
Shoot me a message. I’d be happy to get you a great deal on either arms! Last I checked they’re in stock too. Free shipping :)
