Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
Camber Plates?
This is a discussion on Camber Plates? within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
I am trying to get some info. I have a 2014 Raptor. I installed a new wheel tire combo for ...
Sponsored By: Fox - Redefining Ride Dynamics
Old 04-28-2018, 08:39 PM   #1 (permalink)
Default Camber Plates?
I am trying to get some info. I have a 2014 Raptor. I installed a new wheel tire combo for the truck. 20 x 9 Fuel Octane wheels, +20 offset, and BFG KO2s 35 x 12.5 R20. I took the truck to check the alignment and found out from the dealer that I need more negative camber on the front and would need camber plates. I thought the stock suspension had enough camber adjustment without having to get aftermarket plates. Side by side the 315/70/17s look to be the same size as the KO2s. Am I missing something? I have not performed any other suspension mods. I just want to make sure the dealership isn’t trying to get over on me. Thanks.
VADER332 is offline   Reply With Quote
Old 04-30-2018, 11:25 AM   #2 (permalink)
BenBB's Avatar
Originally Posted by VADER332 View Post
I am trying to get some info. I have a 2014 Raptor. I installed a new wheel tire combo for the truck. 20 x 9 Fuel Octane wheels, +20 offset, and BFG KO2s 35 x 12.5 R20. I took the truck to check the alignment and found out from the dealer that I need more negative camber on the front and would need camber plates. I thought the stock suspension had enough camber adjustment without having to get aftermarket plates. Side by side the 315/70/17s look to be the same size as the KO2s. Am I missing something? I have not performed any other suspension mods. I just want to make sure the dealership isnít trying to get over on me. Thanks.
Hmm I call bullshit. The alignment cams don't increase camber adjustment, they DO make it easier to align and should keep it that way under abuse, but they don't gain anything since the slot is the same width. That said, yeah they are a good idea, and cheap insurance, but by no means a necessity. If you really do need more camber adjustment you need aftermarket adjustable UCA's...again there are upsides and downsides to them (stronger, adjustable vs. expensive) but unless the whole frontend and/or frame is tweaked even those probably aren't necessary (could potentially be borderline from what I understand but even at the extreme isn't going to be a serious problem). Good luck.
"All in all it's a good life, I got what I want, I can't complain"-5FDP
BenBB is offline   Reply With Quote
Old 04-30-2018, 12:31 PM   #3 (permalink)
RDFTS's Avatar
aka Rick
Those wheels are actually +20mm not -20mm and have 5.75Ē back spacing. So only 14mm from stock.
Even though I do not condone the decision for 20ís on a GEN1, what is an alignment plate? Iíve heard of alignment cam kits but like BenBB stated they do NOT allow more camber than the stock lower slot and he shouldnít have to get aftermarket UCAís to compensate. Usually the adjustable UCA are designed for when you lock in the lowers and do the camber adjustment from them instead of from the lowers.
Want to know exactly what this dealership is selling?
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR & Raptoberfest 14'/15'/16'/17'/18' | Time Attack 14' | Snoball 15'/18' | AR Run 15' | TRR Baja 16'/18' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 04-30-2018, 09:27 PM   #4 (permalink)
Thanks for the reply. I asked the Tech performing the alignment how did the turck get out of spec in the first place. He stated that the truck could have taken some off road abuse. That shocked me because I have had the truck off road maybe 10-15 times in 3 years. The surfaces were sand, soft dirt, or dirt lanes. those were all flat surfaces too.
Old 04-30-2018, 09:51 PM   #5 (permalink)
sounds like bullshit. just do your own alignments. Most shops are clueless.
"The only good pace is a suicide pace and today is a wonderful day to die"
reaper1441 is offline   Reply With Quote
Old 05-01-2018, 08:40 PM   #6 (permalink)
LOL. I agree with you on that. I am glad we have this forum. You guys do help to keep members from being ripped off by the stealerships.
Old 05-01-2018, 09:06 PM   #7 (permalink)
you can do your own alignment in your driveway in about an hour with simple tools and some string. same way formula 1 does it.
Old 05-09-2018, 08:50 AM   #8 (permalink)
Canuck714's Avatar
read the sticky "You and your Raptors alignment". Print off the specs and find a new alignment shop.
Do yourself a favor though... Know what can be adjusted and where they adjust that on your truck before some tool at the shop tells you that you need a camber plate, that doesn't exist.
2014 SCrew, 801a, Roush Stage 2, FOX 3.0 with DSC Front, FOX 3.0 rear, Method NV, 37 12.50-17 BFG K02.
Canuck714 is offline   Reply With Quote
Old 05-16-2018, 09:26 PM   #9 (permalink)
Are these the stardard specs that you refered to? Thanks.
Caster:
+4.0 to +4.3
Camber
-0.3 to -0.2
Total toe
+0.2 to +0.25
Old 05-20-2018, 11:28 AM   #10 (permalink)
I did find that the front cam bolts were all over the place. I would have though they would have been close to the same spot in the slotted holes.driverside-f-cam-bolt.jpg
Camber spec? Marxs911 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 3 04-11-2016 12:54 PM
GEN 1 Adjusting 3.0's and Alignment Camber RDFTS Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 20 04-06-2016 11:14 AM
Camber Adjustment for Top Perch? RAPTILE Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 4 02-13-2013 07:44 AM
Front wheel camber? whtrapta Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 8 01-29-2013 04:22 PM
caster/camber plates w/outlaw bumper? henkeljr Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 11 05-02-2012 01:55 PM
