Squatting Dog
Here is a solution for the big dogs running Fox 3.0's....
External Cooling System (ECS)
The External Cooling System (ECS) is an option on all new and existing 3.0, 3.5, and 4.4 FOX bypass shocks. The ECS cooling system, code named "Cactus Cooler", during development, effectively drops fluid temperatures up to 150 degrees. Without pumps or fans, it uses the normal motion of the shock piston as it cycles up and down to pump the fluid through a billet aluminum and stainless steel heat sink.
$500 a piece
Includes the cooler itself, hoses, and the modifications to shock to except the hoses that attach the cooler to the shock.
-Greg
$500 a piece
-Greg
