Are you wanting to compare to the ICON in it's default native setting or without the spacer ring?
From ICON installation sheet:
The standard configuration of the ICON bump stop kit (95120) incorporates a spacer ring between the bump stop and the clamp sleeve in which it mounts. With this ring installed in its standard configuration the suspension stops at the same position as factory and is compatible with stock OEM shocks and standard Icon bypass rear shocks (95200).
The new RXT rear shocks have a shorter compressed length allowing the suspension to compress further than stock for increased wheel travel. This allows us to remove the spacer ring to position the bump stop higher in the chassis
