brakes squeaking
Gsteve
My 14 has 75,000 miles and i replaced the front brakes a bit ago. They now squeek a bit when the brakes arent being used. As soon as i touch them it goes away I took it into the shop and they said things needed lubing. That fixed it for a while and now its back. What exactly is it and how do i fix it?
Jhollowell
Everett, wa
Id make sure you have the pads installed correctly. The one with the double jump goes on the inside.
See this thread
http://www.fordraptorforum.com/f195/psa-raptor-front-brake-pad-installation-issues-43316/
Next make sure all metal on metal contact areas are lubed. Back of the pads where the pistons hit the pad and all the sliding interfaces between the caliper and pad. Have you replaced your rotors as well? If you only had them turned you may want to invest is some new ones.
I bought the powerstop set from stage3motorsports and am very happy with it.
G
Gsteve
See this thread
I just had them turned , might have to look into new if i keep it much longer. Thanks
