Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
Ball Joint replacements
This is a discussion on Ball Joint replacements within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Mine had to be pressed in...
Like Tree9Likes
Sponsored By: Fox - Redefining Ride Dynamics
Old 11-25-2014, 11:19 PM   #21 (permalink)
All The Way's Avatar
All The Way is offline   Reply With Quote
Old 11-26-2014, 08:33 AM   #22 (permalink)
Yukon Joe's Avatar
Originally Posted by RangerRob View Post
Are you guys sure K500193 is the correct part number? I ordered two from Rock Auto, pulled the stock BJ out and the MOOG joint slides right up into the arm and there's a little wiggle room in there. It should fit tight and have to be pressed back in. Definitely not the case with the MOOG joints I received. The boxes they were in both have K500193 on them too.
Got any pictures?
Donate to Avery and be entered into a raffle for an awesome prize for your Raptor
November Pay It Forward Event!
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 11-26-2014, 09:12 AM   #23 (permalink)
TheJoker's Avatar
I checked 2 sites and this is the correct part number. Is the part number stamped on the bottom of the ball joints? They should have to be pressed in. Are the sides splined like these AC Delco ones?
If they don't fit snugly, I would give Moog a call 888-406-2330
KaiserM715 and Yukon Joe like this.
Originally Posted by Wilson View Post
big boobs impress me big words not so much
TheJoker is offline   Reply With Quote
Old 11-26-2014, 11:09 AM   #24 (permalink)
KaiserM715's Avatar
Kaiser Söze
I checked the Moog site and they list this number specifically for the Raptor. The other F150s are a different part number, K500008.
From the pic on Moog's site, they are not splined.
+1
'10 Raptor - My build
'08 G8 GT
- sold
'04 MazdaSpeed Miata
'67 Jeep Kaiser M715 - sold
Join the Blue Ribbon Coalition . . . it's YOUR Public Land!
KaiserM715 is offline   Reply With Quote
Old 11-26-2014, 11:26 AM   #25 (permalink)
RangerRob's Avatar
Thanks for everyone's replies. I'm gonna try getting an OEM joint from Ford to see if it will fit tight into the arm. Only other thing I can think is maybe the bj cup stretched some when I pressed out the old joint. I'll be really pissed if I have to replace the LCA.
'12 Tux Black SCAB, RPG susp., Glassworks front glass & liners, BajaDesigns 60" OnX6/44" Onx/20" Stealth/XL Pros/amber S2s, MagHytec cvr, PA trans pan, Lowrance HDS5, Kenwood radio, SDHQ dbl shear knuckle gussetts/Doubler Plates/brake lines/ABS & Vac. guards, custom bumpers, 37" BFG KRTs on Candy Red Method NVs, Kooks LTs, MagnaPack, 5-Star tune, Raptor Retrofits
RangerRob is offline   Reply With Quote
Old 02-02-2017, 05:59 PM   #26 (permalink)
Ratpatator's Avatar
Originally Posted by Mil T View Post
Been there done that one. That's actually was my first idea of the noise but I knew I had already replaced the aluminum ones to the Chrome moly ones. I checked all the bolts that the upper mount uses but they were all tight.
I'm going to pull the entire front suspension on both sides off and inspect it with a fine tooth comb. I don't think it is the sudden drop return of the shock after a small bump clunk that is typical of the 3.0 shocks. I know what that sounds like.
Thanks again for the ideas.
Sorry I realize this is an older post but I was reading about our situation and I have an identical problem. Sound comes from both sides but is a lot louder and more frequent on the passenger side. I was wondering if you have figured out what the clunk was for sure. Im having a hard time believing that this is the shock sound, I'm thinking ball joints also as everything is fairly new except LCA and UCA. I also have the 3.0. Any advice would be greatly appreciated.
Ratpatator is offline   Reply With Quote
Old 02-02-2017, 10:52 PM   #27 (permalink)
I'm putting in the MOOG BJ's and new tie rods this weekend as well as cleaning out and re-lubing the IWE and hub area. I'll post up on the results. Hopefully, I can get it done soon enough to knock out the alignment also. I think my front end is 2inches higher than it was the last time I got an alignment so got a little issue there.
UPDATE
Got the ball joints and tie rods replaced and did the second torquing today.
90% of the noise is gone now. Definitely, have some other things going on but I'm not feeling anything thru the steering associated with the noises. Most of the noise sounds like loose skids and noise from the rear. At least now I can hear the noise though.
My passenger side IWE is messed up though. No metal shavings but had good old Colorado granite sand packed in it. Cleaned and regreased for now but it is on the list for replacing as well as hubs.
SCT 5 Star Tune, AFE Intake, Fox 3.0, Stainless Works Cat Back Exhaust, Method Double Standard Wheels
http://www.fordraptorforum.com/image...ine=1371963757
Grunzen is offline   Reply With Quote
Old 07-12-2017, 09:48 AM   #28 (permalink)
Could a bad/worn ball joint or bushing in the control arm be the root of a clunk sound when traversing very shallow abrupt level changes on and off road?
40oz is offline   Reply With Quote
Old 07-16-2017, 08:10 PM   #29 (permalink)
Could be a upper one also. I know the right upper is smoked and makes all kinds of noise.
40oz likes this.
2011 Headlight Bulb Replacements? Mark Ducati 2011 Ford SVT Raptor Forum (Reply Only) 36 02-25-2017 11:21 PM
Ball joint out at 38k miles Stang Ford Raptor Problems and Questions Forum 3 07-29-2014 12:04 AM
iPhone and iPad Screen and Battery Replacements! BearLeeAsian Garage Sale 1 07-01-2014 09:36 PM
Icon stock replacements?? Off Road WannaBe ICON Vehicle Dynamics 25 04-01-2013 04:04 PM
OEM Tire Replacements: $200 each? BigJ Ford Raptor Wheels & Tires Forum [GEN 1] 1 06-26-2010 07:39 PM
