Anyone ever seen this setup for the rear shocks?
Aaron313
El Paso, TX
Came across this truck on eBay and I thought this truck had a lift kit installed but the front suspension is on the top perch and the rear shocks have some sort of extension on the bottom half which I've never seen before(pretty sure this has a negative effect on performance) but the truck looks massive! 9f2c08f8c7a5243c3767f5ddbbc30172.jpg3fb46c47afe345f197ffb01a293aed2d.jpg
Deleted member 12951
Descriptions states 5" custom lift. Not sure how they came up with that but definitely a lift block under the existing factory block. And 20" wheels with 37" nitto's.
Aaron313
Aaron313
El Paso, TX
Lol I don't know if looking at this at the early hours of morning threw me off but I could've sworn the bottom of the shock sticked out further from the rear end than normal lol, sorry guys [emoji58] I know the rears aren't adjustable but I thought he had some sort of extension connecting to the bottom of the shock to get that length #slowlygoingcrazy
JJ f150harley
Traverse City MI
Looks like it could be the fabtec 4in lift with the coil overs on top perch for that extra 1in. I know they put spacers on both the front and rear factory fox shocks.
Sent from my SM-G920V using Tapatalk
Towerhog
Southeast CT
Im not a fan of lift blocks (be it stock or aftermarket). The stock setup isn't that bad. But adding an aftermarket block to the stock block to increase ride height is just idiotic. Talk about a nightmare for axle wrap.
Besides, whats custom about that setup?
