Adjusting front ICON 3.0's
  • Start date
Need some help. According to Birdman's post, he has 5 threads showing on top:
http://www.fordraptorforum.com/f9/icon-3-0-coilover-upper-control-arm-skid-plate-installation-write-up-20927/index7.html#post371861
He also states that 26.25" is mid-perch (which is what I was at with stock shocks before upgrading but never measured) on step 18. And 26.5" is ICON setting.
http://www.fordraptorforum.com/f9/icon-3-0-coilover-upper-control-arm-skid-plate-installation-write-up-20927/#post357720
But I don't see what size or type of wheels/tires he has so I know that makes a difference.
I measured mine and it was 25" on the driver and 25.5" on the passenger. I have stock beadlock wheels and stock BFG. I did just now raise the driver side to match the 25.5" but still seems low. Passenger side has 5 threads and driver now has 6 threads showing.
For those out there that have ICON's with stock wheels and tires, where does yours measure? And do you have 5 threads showing?
SlimChaChi
NJ
i'll take a look some time tonight and measure. from what i was told, shocks are set at what mid perch would be. i'm sure there will be some that measure differently...now you got me curious...
RLTW
TX
Just a note, you may see your height change on one side depending on this amount of fuel in your tank. So if you adjust to even, it still will end up off.
