Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - Member's Area > The SuperDuty Section
7.5 engine question
This is a discussion on 7.5 engine question within the The SuperDuty Section forums, part of the Ford Raptor Forums - Member's Area category!
I have an old '96 f-250 heavy duty (1 ton) 7.5 (460) engine. So my question to all you ford ...
Old 08-16-2011, 03:38 PM   #1 (permalink)
Rat
Senior Member
Default 7.5 engine question
I have an old '96 f-250 heavy duty (1 ton) 7.5 (460) engine. So my question to all you ford technicians is the left rear freeze plug rusted out at 75,000 miles. I got it out without removing the Banks headers but should I replace all of the freeze plugs ? I can see 4, are there 2 on the rear of block ? I am replacing water pump, hoses, thermostat. What else while I have it torn down ? Thanks for any suggestions
Rat is offline   Reply With Quote
Old 08-16-2011, 03:59 PM   #2 (permalink)
Hockster's Avatar
My 45ft Bluewater Party
I would inspect the rest and if you see rust forming then replace them... Boy, been a whils since I looked at the back of a 460... There are usually 2 back there...
Hockster is offline   Reply With Quote
Old 08-16-2011, 04:25 PM   #3 (permalink)
Rat
Senior Member
The outsides look ok, but not sure on the rears. I'll pull some easy ones to see. Thanks !
She's a big old gas suckin truck. But I like her, she been good to me for quite a few years. Like an old friend, gotta keep her around.
Old 08-17-2011, 12:24 AM   #4 (permalink)
19-Kilo's Avatar
ΜΟΛΩΝ ΛΑΒΕ!
on an older engine like that I would be hesitant to fix something that is not broke (the other plugs) may be more trouble than its worth and may make new problems.
just something I have had bad luck with.
19-Kilo is offline   Reply With Quote
Old 08-17-2011, 01:54 PM   #5 (permalink)
Rat
Senior Member
I know, why stir up a hornets nest when they are not bothering you ! There's always the "oh shat" factor to keep in mind. She's a good ole truck, work horse.
Tags
460, 7.5, freeze plugs
Favorite Engine 6.2 The SuperDuty Section 18 04-01-2012 11:23 AM
Engine shut off Hoffer Ford SVT Raptor General Discussions [GEN 1] 13 02-22-2011 04:10 PM
engine power PSHOLAR Ford Raptor Problems and Questions Forum 5 01-14-2011 06:14 PM
