- Joined
- May 23, 2011
- Posts
- 1,185
- Reaction score
- 1,286
Ever worry about your stock drive shaft getting knocked around, bent or mangled? The answer is here with the new racing drive shafts from Arizona Drive Shaft! Made specifically for the Raptor, these drive shafts are made with the same materials used on the off road race trucks. Even with a hard enough hit, with significant damage, these drive shafts will hold up and get you home.
Arizona Drive Shaft is "THE" go-to drive train shop for the majority of the big Trophy Truck race teams.
There are two versions. Steel and Aluminum. The Steel version (Model RST6000) will only fit the Super Cab. Aluminum will fit both the Super Cab and the Super Crew.
The RST6000 is a 3 1/2 D.O.M. .083 wall steel drive shaft that directly replaces the factory 4" .083 aluminum shaft. These shafts will maintain a smooth ride at highway speeds while also giving you far greater peace of mind. Being made of the same tubing used to build trophy truck shafts, it can with stand much more off road abuse.
The aluminum version comes with a .125 wall thickness which is much thicker and stronger than stock and still maintaining a lite weight.
Now Available at RaptorAddict.com
Pricing:
Steel RST6000: 498.00
Aluminum: 690.00
Pricing:
Aluminum: 690.00
