Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forum Supporting Vendors > Outlaw Offroad
Outlaw Offroad
New Alpha 1 Spindle Gusset
This is a discussion on New Alpha 1 Spindle Gusset within the Outlaw Offroad forums, part of the Ford Raptor Forum Supporting Vendors category!
Like Tree14Likes
Old 10-17-2012, 10:04 PM   #1 (permalink)
Outlaw Offroad's Avatar
Default New Alpha 1 Spindle Gusset
The Alpha1 Weld on Spindle Gusset Kit.
Just like other Alpha 1 products the new Raptor spindle gusset was designed knowing there was a need in the Raptor marketplace. The spindle gusset kit is the perfect low cost answer to preventing the OEM spindle (steering knuckle) from bending at the top mounting point. The bending is caused by the top 90 degree ear mounting point of the spindle going through full compression and the angle of the tapered pin in the factory arm causing the spindle ear to twist and bend. The bending is ever so slight at first but gradually gets worse over time causing negative camber and premature tire wear. The gusset is a full weld on kit and it is necessary for any off road enthusiast.
A must have reinforcement for anyone who wants to play in the dirt with your Raptor.
Strengthens the factory cast spindle uprights and prevents the knuckle from bending at the 90 degree top mount. This damage occurs during full compression with the factory UCA.
3/16" 4130 chromoly laser cut steel brackets.
Welding and grinding are required to install.
Any questions call the shop 949-581-5001
Raptor Gussets
Sitting on the Spindle
Welded on RSV3
Welded and painted
Alpha1 Spindle Gussets
Ford Raptor Specialists!
Outlaw Offroad caters to all truck owners. But the Ford Raptor is our passion.
Our in-house company, Alpha 1 Innovations designs, fabricates and tests high quality, American Made Raptor components.
We also sell Bumpers, Bump Stop kits, Wheels, Tires, Performance, Suspension upgrades, GPS/Radio, LED and HID Lights.
Outlaw Offroad is offline   Reply With Quote
Old 10-17-2012, 10:15 PM   #2 (permalink)
onesickpuppy's Avatar
Good stuff guys!!!
Mods: Mid perch with Farrar Racing tuned position sensitive by-pass shock mods, Sway bar delete, custom MFT back screens, IC-706MlKll installed, Spot connect, HF, VHF& UHF antenna installed, duplexer, PCI intercom with street legal head phones and helmets, Raptor claws with D2's, 30" curved behind grill light bar Outlaw/Fox bump stops, Deaver +2's W/ 1" block, bed rack powder coated fender flair color, with 2 factory beadlock wheels and BFG's Lowrance HDS-5M, VIM
onesickpuppy is offline   Reply With Quote
Old 10-18-2012, 09:52 AM   #3 (permalink)
KaiserM715's Avatar
Kaiser Sze
Originally Posted by Outlaw Raptor View Post
$99 is a good price for that gusset. I might have to see if I can find someone who is good at welding CroMo to cast...
'10 Raptor - My build
'08 G8 GT
- sold
'04 MazdaSpeed Miata
'67 Jeep Kaiser M715 - sold
Join the Blue Ribbon Coalition . . . it's YOUR Public Land!
KaiserM715 is offline   Reply With Quote
Old 10-18-2012, 10:14 AM   #4 (permalink)
treypal's Avatar
Lord of the Raptors
Yeah. Any info on welding that thing up?
TRR Website
treypal is offline   Reply With Quote
Old 10-18-2012, 10:16 AM   #5 (permalink)
BlueSVT's Avatar
Sweet... can't wait to have it installed next week!
www.expeditionxoffroad.com
BlueSVT is offline   Reply With Quote
Old 10-18-2012, 10:23 AM   #6 (permalink)
Lance Vincent's Avatar
1 Can That mother just be MIG welded ???
2 Can it be done on the truck with some wet fire blankets around soft parts?
Looks like a nice part
Thanks Lance
Lance Vincent is offline   Reply With Quote
Old 10-18-2012, 11:04 AM   #7 (permalink)
Hockster's Avatar
My 45ft Bluewater Party
Thanks Lance
Ya its quite easy to weld steel to cast... steel is slightly harder than cast iron, and therefore combines fairly easily
Hockster is offline   Reply With Quote
Old 10-18-2012, 11:06 AM   #8 (permalink)
KaiserM715's Avatar
Kaiser Sze
For a MIG, do you need to use different wire?
'08 G8 GT
- sold
Old 10-18-2012, 11:10 AM   #9 (permalink)
Hockster's Avatar
Nope... Standard MIG wire works. They are really close in carbon content... Cast has a bit lower melting point...
Old 10-18-2012, 11:30 AM   #10 (permalink)
To ensure the strongest weld you should really preheat the cast part before welding. After welding is complete slowing the cooling down is also a good idea(wrap the part in a old sleeping bag overnight for example)
DieselD is offline   Reply With Quote
New Raptor Alpha 1 Billet TT Upper Arm Outlaw Offroad Outlaw Offroad 21 10-31-2012 11:34 AM
Bolt in Rear Frame Gusset Kit Addictive Desert Designs Addictive Desert Designs 21 03-27-2012 07:02 PM
F/S - AZ - SDHQ rear frame gusset kits 19-Kilo Garage Sale 16 01-22-2012 10:21 AM
ADD bumpstop/gusset high speed test runs Squatting Dog Addictive Desert Designs 10 10-09-2011 11:28 PM
