Outlaw Offroad
- Joined
- Apr 7, 2011
- Posts
- 624
- Reaction score
- 311
If your planning on air your tires up after a day of plain in the dirt or if you need that trail side repair and air tools are needed. The Source portable air system works great for any job.
We have the complete system on sale for $349.99 with free shipping.
The SourceTM is a complete portable air system consisting of an aluminum cylinder of pressurized liquid CO2 which is released as a vapor through The SourceTM HyperFLOmaxTM Regulator. Supplied with a 20 foot high quality COMP-FLEXTM hose, quick connects, and tire ball chuck... nothing else is needed. The most complete and economic high quality CO2 portable air system on the market.
The SourceTM is the contractors, off road enthusiasts, weekend warrior, automotive ace, and handyman’s answer to a complete and reliable portable air system. Most important - it’s silent, lightweight, portable and fast.
What is The SourceTM?
The Source is a complete portable air system consisting of an
as a vapor through The Source HyperFLOmaxTM Regulator. Supplied
with a 20 foot high quality COMP-FLEXTM hose, quick connects, and tire ball chuck... Nothing else is needed. The most complete and economic high quality CO2 portable air system on the market.
Why do you need The Source?
The Source is the contractors, off road enthusiasts, weekend warrior, automotive ace, and handyman’s answer to a complete and reliable portable air system. Most important – it’s light weight, portable, and fast. The Source is a silent high pressure air source.
How does The Source work?
Simplistic! The Source is a high powered – high energy CO2 air system. CO2 is filled as a liquid and evaporates to gas (air) through the regula- tor and out the hose to the tire , tool, or inflatable product. As more gas is consumed, more liquid evaporates into gas generating more pressure. This process allows much more volume than other commonly used nitrogen, shop air tanks and scuba tanks.
Does the pressure drop as The Source depletes?
Absolutely not. The Source uses the evaporated liquid CO2. As long as there is liquid remaining, your tank will have full pressure.
How does The Source compare to a 5 gallon air tank?
The Source (10 LB TANK) is less than half the size of a
5 gallon air tank but holds 20 times the capacity. A 5 gallon
air tank pressurized to 125PSI will inflate two 33x12.5050x15
truck tires from 10-20PSI. The Source (10 LB TANK) will inflate thirty nine (39) tires the same size, taking only 30 seconds a tire!
Does The Source come in any other sizes?
The Source is available in 5lb, 10lb (the most popular), 15 lb, and 20lb tank sizes.
How safe is The Source?
Every component in The Source is precision, professional and of heavy duty quality utilizing only the strongest materials. All systems are built safe. The lightweight
cylinder is manufactured from 6061-T6 aluminum with a service pressure of 1800 PSI and a safety burst mechanism of 3,000 PSI. The safety is
designed to “let go” when the cylinder is exposed to extreme heat, fire or overfill. This safety factor is very high when considering CO2 at room temperature is 700-800 PSI. The valve protection “ Rock GuardTM” carry handle has a dual purpose; manufactured from high impact materials
protecting the on/off valve and also making The Source easy to carry. The Source adheres to all DOT (Department of Transportation) and CGA
(Compressed Gas Association) requirements. Please Note: Use precaution and common sense whenever using, handling high pressure gases
and equipment.
Why CO2 instead of Air or nitrogen?
The Source stores CO2 in liquid form which results in air storage 3 times the energy of nitrogen or air. This means you would be storing
three (3) nitrogen tanks or one CO2 tank using The Source.
Is CO2 safe on my equipment?
CO2 is non-toxic, non-corrosive, and totally inert. This means its safe on your air tools, tires, and metal wheels. The thermal expansion is
similar to air once released from the tank.
How can The Source be mounted?
The Source can be mounted in any position. The brackets are drilled with holes on the base and back to permit many mounting options.
However, the Source must be situated at least 30 degrees to operate properly. It is recommended that you mount or stand the Source in a
vertical position to limit unnecessary handling before use.
How do I get The Source Filled?
Most local welding supply, fire extinguisher, paintball supply stores and industrial gas supply locations can fill The Source tank very quickly.
Notes
This System Includes
Lightweight DOT Aluminum Cylinder with 10lb carbon dioxide capacity = 640 gallons of shop air
3000PSI Safety System
HyperFLO Max Aluminum Regulator, adjustable from 0-250PSI, 33CFM
Durable Powder Coated Finish
20ft Comp-FLEX Coil Hose assembly with quick connects
Quick Connect Standard Tire Chuck Rock Guard Sport Handle
Vehicle Mounting Bracket
Tire Air Up Rate
The Source Air System | Outlaw Raptor
