ThatGuy88
So I swapped all my marker tail and turn lights with LEDs. As i forgot to compensate for is the hyperflash. They were cheapies through work so though they dont have built in resistors. Did find the posts but wasnt sure if anyone has had luck with having a ford tech nuts with the BCM or put in line resistors in. I read some guys still had the hyper with a bcm reprogram. Or what wires guys tapped the resistors. If anything Ill bite the bullet and order bulbs with built in resisitors cause I really dont want to hack the wires.
