NTXrptr
Has anyone used the wire harness supplied by Vision X with the Light Cannon pair/kit to wire them up to an up fitter switch?
I'm planning to use these as my hood lights and have the Outlaw claws installed.
I've wired up rigid lights (basically plug and play) and know how the Ford side of the wire harness works with the up fitter switches. Just wondering if the Vision X harness can be used.
I have the lights in hand. They just didn't come with any wiring instructions/diagrams.
The harness has two weather proof connectors each with a ground with both of them having their power going in to a relay. The relay has a ground, a second wire with a fuse (power?) and a third wire going to a switch with a fuse after the switch.
I can perform mechanical mods all day long, but this electrical stuff is black magic....
Thanks!
Thanks!
