GEN 1 Thrid Brake light LED Replacement
Darthyota
Alberta Canada
Our S2 Sport, Flush Mount lights fit nicely in there. Definitely a quality option for those looking to mount a Dust/Safety Light and Cargo Light up high without a roof rack.
-Bailey, Baja Designs
[email protected]
you guys need to make an s5 that has 2 reds 2 ambers and 1 clear for those instead of 2 s2's
4x4TruckLEDs.com
Baja Designs doesn't make that... that bracket is made by another company and they are using the BD lights.
Baja Designs
We do have the RTL-M now which would be the closest thing to what you're looking for. It does not have Amber however.
M stands for Mini and at 6-inches this light bar will be exceptionally useful on vehicles where space is limited. The RTL-M includes 5 Red LEDs which function as your tail and brake lights, 2 Center Mounted White LEDs with Flood optics, and 1 LED the projects light down for license plate illumination. We are very excited to bring this Mini RTL to market for Jeeps, Raptors, Toyotas, and other great applications. We will be offering the RTL-M in 2 Models and 2 Mounting Accessories available including a License Plate Mount and Spare Tire Mount.
RTL-M w/ License Plate Light - $249.95
https://www.bajadesigns.com/Products/RTL-m-6-inch-rear-Light-Bar.asp
RTL-M w/o License Plate Light - $219.95
https://www.bajadesigns.com/Products/RTL-M-6-inch-Light-Bar-No-Plate-Light.asp
Mounting Kits:
RTL-M, License Plate Mount Kit - $19.95
https://www.bajadesigns.com/Products/RTL-M-License-Plate-Mount-Kit.asp
RTL-M, Spare Tire Mount Kit - $79.95
https://www.bajadesigns.com/Products/RTL-M-Spare-Tire-Mount-Kit.asp
[email protected]
Darthyota
Alberta Canada
Mounting Kits:
[email protected]
yes but the s5 could also be used as a generic tail/turn/brake/reverse light platform for buggies, kit cars and other custom or specialty vehicle applications.
downforce137
In Diana
it makes sense..there's not really a dedicated amber chase light out there. I think rigid missed the mark, because that amber halo isn't bright enough for what we need.
we all want a clean looking light that will provide a bright amber/chase dust light, stock functioning brake/running and a cargo light in one.. seems like some are retrofitting ambers into the gen2 cargo lights, and the miller light is great, although maybe a bit pricey and race truck looking.
downforce137
In Diana
How is this coming along?
i have most of the engineering done, except the body gasket. im pretty sure most of the water instrusion problems are from the screws being over-tightened and the lamp getting broken where the screws push the grey backer away from the lens causing a water leak. retrorubber is an option for the body seal, but its a big pain if you had to remove it. haven't worked on it much because i was rebuilding shocks and prepping for snoball, but a buddy needs one so i'll get back into this week or next.
Raptized
Raptized
Raptorida
Cool. Mine went from 2 working leds to now none. Maybe interested in a rebuild and could probably manufacture my own gasket.
93,145
56,419
TwistAir
