testing LEDs???
nsdq3
nsdq3
West Point, VA
harness is cut behind the female deutsch connector. I feel like a ********, this should be so simple. Also got two Baja designs 4" HIDs. They are absolutely 24V, but came on nice and easy when I hooked them to two 12V in parallel. Nothing for the D2s though
Mac
NJ
Did you check the battery to make sure it was putting out 12v and is not undercharged? Just had a problem with of my work trucks installed a pair of LED beacan and they would not work checked the power wire and it on had 6V ended up being a bad switch
nsdq3
nsdq3
West Point, VA
battery was exactly 12.0 volts. I know rigid has had the moisture issues, but I have not seen it where they would just not work, especially seven of them. I guess I will figure it out when I get home and can plug them into where the existing duallys are, I know that works.
