Rigid wiring help
PCDan
Park City
So I have everything mounted up - now for the fun part ha! figure its a 6 pack job :)
10 Duallys up front (6 spot, 4 flood)
20 " bar in bumper
2 Duallys in back bumper
- Thinking of putting all front duallys on switch 1 , wire all hot leads together and all ground together (but I could put spots on one switch and the floods on another?)
- 20" on switch 2
- rear bumper duallys on switch 3 -
Thoughts?
Please post links to wiring help that might save me some time ..(I can't find Birdmans instructions which are referenced in other posts as good?) ( also I still can't figure out why the upfitter switches aren't just wired straight through to engine compartment?)
Thanks -
J DAMAGE
NJ
20 " bar
- 20" on switch 2
Thoughts?
Please post links to wiring help (can't find Birdmans which is referenced as good?) ( also I still can't figure out why the upfitter switches aren't just wired straight through to engine compartment?)
Thanks -
First question do you plan to add more lights or any other accessories down the road? If so you'll be doing the extra switches mod, if not then best bet is to separate the floods from the spots,
SWITCH #1 6 spots, SWITCH #2 floods, SWITCH #3 20" bar, SWITCH #4 Rear duallys, add a relay to the system so the rears come on when in revers, and can be switched on if needed any other time. 1 thought others will chime in. Also use terminal blocks for your wiring of the lights, so if by chance one should fail, your not pulling a ton of wiring apart for just one light.
http://www.fordraptorforum.com/f170/%A1m%E1s-factory-upfitters-easy-access-wiring-30527/
http://www.fordraptorforum.com/f170...r-switches-20335/?highlight=upfitter+switches
PCDan
PCDan
Park City
I think this is everything I will be putting on the switches, so your switch set up sounds good.
I like your idea of having the rears come on in reverse ... I'm not familiar with how to wire the relay ... Maybe someone can post a how-to link on that.
J DAMAGE
NJ
PCDan
PCDan
Park City
PCDan
PCDan
Park City
If I have power at my Aux3 switch (switch light works) but no power at the AUX3 wire behind the glovebox, can I rule out a relay wiring problem? Seems like the relay is between the power and the switch?
Is this the inline order?
12V - fuse - relay -switch - wires under dash
Sorry, off topic, I started a new post on this issue
