aR4CE
Going to tackle rigid dually fog brackets soon, and I'm throwing around mounting ideas.
-Kit comes with sheet metal screws, of which I'm not a fan in general.
Option 1: Deal with it and install as included.
Option 2: Nutsert/rivnut install. Time consuming, but more peace of mind since I can secure the bracket better.
Option 3: Rivets. Semi-permanent, but still deciding on structural integrity and movement.
Option 4: Build nut strip/plate which slides inside the support beam, into which I can secure bolts. (would require building plate or strips with nuts welded to them)
I'm looking for the best way to secure them where I won't get movement, backing-out, or CORROSION.
Any experience/ideas would help!
