Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - Modifications > Ford Raptor Lighting Modifications Forum
Sponsored Ads
Rigid Dually back up lights installed
This is a discussion on Rigid Dually back up lights installed within the Ford Raptor Lighting Modifications Forum forums, part of the Ford Raptor Forums - Modifications category!
Register to remove these ads. It's free! Installed a couple Rigid Industry Dually's for some added back up light since ...
Old 08-15-2010, 02:14 PM   #1 (permalink)
pirate air's Avatar
will plunder your booty
Default Rigid Dually back up lights installed
Installed a couple Rigid Industry Dually's for some added back up light since the stock B/U lights suck. These are white flood patterns. The popular place to mount these is on the rear spring hangers, after some test fitting I have to agree. So that's where mine went.
I wired them up to my number 4 up fitter switch. If anyones looked into the Rigid led lights, they know that the lights require very few amps to operate. The up fitter switch circuits are fused for more amps from the factory then whats desired for the Rigid's. Trying to find a 5 amp (or low amp) micro fuse is almost impossible. I have seen some Raptor owner's using inline fuses, which works fine. With an inline fuse, the circuit will be protected by the up fitter fuse up to the inline fuse, AFTER the inline, the rest of the circuit (including the lights) will be protect with the lower amp in line fuse.
But, there's an easier way. You can install a regular ol' mini fuse in the micro's place. It will stick up a little bit, but other wise, be held securely and operate normally.
I know it's kinda worthless without night shot's.... I will work on getting some.
For now,
pirate air is online now   Reply With Quote
Old 08-15-2010, 02:17 PM   #2 (permalink)
pirate air's Avatar
Another fuse shot,
Old 08-15-2010, 02:19 PM   #3 (permalink)
IRONMAN's Avatar
Super Moderator
Nice job Pirate. I'm hoping to do this mod in the future as well.
FordRaptorForum.com
IRONMAN is offline   Reply With Quote
Old 08-15-2010, 02:21 PM   #4 (permalink)
pirate air's Avatar
You will like it, it's so much better.
Old 08-21-2010, 06:17 PM   #5 (permalink)
pirate air's Avatar
Night shots
Old 08-21-2010, 06:35 PM   #6 (permalink)
6.2's Avatar
6.2
that's awesome, you must find it way nicer
I don't own a Raptor. I own a 2006 Ford Ranger.
6.2 is online now   Reply With Quote
Old 08-21-2010, 07:37 PM   #7 (permalink)
IRONMAN's Avatar
Super Moderator
Sweet set up. This is a must.
FordRaptorForum.com
Old 10-07-2010, 12:07 AM   #8 (permalink)
nodak's Avatar
Originally Posted by pirate air View Post
do you have a backup camera on your raptor?
nodak is offline   Reply With Quote
Old 10-07-2010, 04:25 AM   #9 (permalink)
BentToast's Avatar
No, he just likes to piss off tailgaters
BentToast is offline   Reply With Quote
Old 10-07-2010, 09:20 AM   #10 (permalink)
GTS RAPTOR's Avatar
Nice mod!
Could you snap a close up pic showing how the dually light brackets are mounted to the rear spring hangers and post it up please?
Now I know what to use my last upfitter switch for.
2010 F-150 SVT RAPTOR 6.2L
GTS RAPTOR is offline   Reply With Quote
HID Xenon Projector Fog Lights IRONMAN Ford Raptor Lighting Modifications Forum 44 03-11-2012 12:56 PM
Mood lights dbmaster Ford Raptor Interior Modifications Forum 31 04-11-2011 07:31 PM
Installed PCP Spider Rear-Diff. Rock Guard BOJANGLES Ford Raptor Exterior Modifications Forum 21 03-22-2011 11:08 PM
Tow Hook Hole Lights FlounderStalker Ford Raptor Lighting Modifications Forum 21 08-16-2010 10:50 PM
Fully Driven Auto Network
