Rigid 54" RDS with ADD mounts
Vanwilder
Anyway you can post up how you ran the wiring? I just purchased this light bar but don't want to drill any holes in my roof to run the wiring. Any info would be greatly appreciated. Thanks and looks good
ADDGrant
Arizona
jason07
DFW, Texas
The brackets are designed to be put in only one place - using an existing rivet/hole underneath the weather stripping. I'm 6'11" and barely notice the bar at all. It definitely isn't in the sight line unless you look straight up. However, it does create quite a bit more wind noise.
Wait......you're 6'11"????
The Macf
Vegas
Length is much better than the others I have seen.
That's what she said.
---------- Post added at 03:46 PM ---------- Previous post was at 03:44 PM ----------
What beam pattern did you get? Output shots?
