Review and Install How to on ORACLE Mirror lights
lexmotorsports goodguy
Great write up, glad you are happy with them. Glad we were able to get them to you before the snowball!.
We are running a FRF special on them if anyone is interested PM me.
iSurvive
Highlands Ranch, CO
I'm a little disappointed by the YouTube video I watched today (same one on this thread). Oracle purposely left the wiring part out and I think it's misleading on purpose.
But thanks for this write up. It helps a lot.
Is it impossible to feed the wires thru the door's wiring harness?
OrangeAddict
OrangeAddict
Raleigh, NC
Since the doors wiring harness is terminated in a modular plug that connects to the main box of the frame, I would say virtually. I made the mistake of forcing that plug loose and liked to never get it back on without removing entire door. That plug is not meant to be disconnected unless the door is off. You am be able to splice in to covering next to the plug but you would still need a wire coming around the corner and thru the door sill.
Another note if you wiring these up. You really need to put a couple of places to disconnect the wire so you can replace the door if needed and more importantly replace the mirror. I have to replace the drivers side one shortly because I broke part of the base plastic off-road.
iSurvive
Highlands Ranch, CO
Very helpful again, thx!
scarrjack
The Park, Alberta
Pretty straightforward, I was nervous of breaking the mirror when I was popping it off but everything went smooth. Without Oranges additional instructions it wouldn't have been as easy, start to finish was about 2 hours.
McDowell
Oklahoma
Thanks. I wanted to do this but didn't know how hard it would be
Sent from your girlfriends closet
