Raptor Barn Lights
Raptized
Raptorida
Way off realm but my brothers barn lights quit working while changing my oil. I opened the old sub panel and it's a disaster. 220 volts in on a 3 wire feed. White black and ground. It's running a 110 volt light setup. Replaced both breakers and nothing. Any ideas?
Raptized
Raptized
Raptorida
pictures of lights and panel would help, i am a master electrician
Hold on
---------- Post added at 01:12 AM ---------- Previous post was at 01:09 AM ----------
So when it was working it was working funky we had to turn the radio on to get the lights to come on if we turn the radio off the lights went offef80ec6b8968575009b6945657e883e9.jpgb8305eff322ab58b81986210d7e4ae0c.jpg
---------- Post added at 01:13 AM ---------- Previous post was at 01:12 AM ----------
So we have a hot white and a hot black line coming in from the main breaker panel there's also a ground wire it's measuring 220 volts and we have brand new 15 amp Breakers they did have the commons and the grounds hook together
---------- Post added at 01:25 AM ---------- Previous post was at 01:13 AM ----------
---------- Post added at 01:53 AM ---------- Previous post was at 01:25 AM ----------
Hold on
Any help is appreciated greatly. I'm in the dark in a barn. Lol
cain072567
so u tested the incoming power from black to white, should read 240 volts or close. (main lugs )
If that is good with the breaker on measure from where the wire connects to each breaker to the ground bar or where all the bare wires go to a bar. With the breaker on it should read 120 volt a/c . Check both breakers in panel. If all that checks out you know its either in the line going to light or the light itself. send pictures of lights next
---------- Post added at 12:04 AM ---------- Previous post was at 12:04 AM ----------
wire feeding panel is too small bit another problem
Raptized
Raptized
Raptorida
Yes. Black to white mains is 240. Black to ground bar is 0 white to ground bar is 240. Can we just take the white wire in the main breaker box off of the 240 breaker and make it a common/ground by attaching it to the other common bar in the main panel thereby only sending 110 to the barn? Nothing down there is 220. Or is that just to be able to run dual breakers? Pics of the lights coming soon.
Raptized
Raptized
Raptorida
So the lights are just normal bulbs on your typical bathroom style fixture underneath the main breaker panel there are three switches one is for the outlets one is for the lights and one is for the outside street light mounted above the barn entrance6c2570983c5afb1df1827d6cc3874d01.jpgdf8d74f031fa61fc7e69bc9288f32a57.jpg18364a13fb8e18a18a8c0cedd09866b7.jpgd45a9dd5ff2d12851f0fdbf1ec7cd295.jpg1c54bd9d5afa0189802f7142406abd30.jpg
---------- Post added at 04:55 PM ---------- Previous post was at 04:53 PM ----------
When I run a tester the Whiteside Maine to the common busbar give me 220 the black side main to the common busbar gives me nothing and the white and black manes together give me 220d84a7a9c66e0b86ed30f88d64c5c45b7.jpg
cain072567
ok u should not have 240 white to ground, should be 110, figure out where its being fed or what breaker. Check voltage there and sned pics, u either have something major wrong if your reading 249 on the white to ground.
Raptized
Raptized
Raptorida
Thank you. I fixed it! I changed the white wire to a common bar in the main breaker box and changed it to 110 volts power going to barn, The barn had 220 power supply for a street light type fixture out front that didn't even work.
