Question about wiring lights
Steve-O
Sumter, SC
Ok, so heres my goal: I want to hook up a set of lights (specifically TMX's Blackhawk X1) so they automatically turn on when I put the truck in reverse. Sounds easy right? Here's the catch... I also want to be able to turn them on manually through the upfitter switches. I drew up a "wiring diagram" of how I think it'll work but I need someone that knows what the hell they're doing to verify it and if its wrong, tell me what i need to do.
pat'sRAPTOR
Everywhere
Depending on the size of the fuse for the back up lights you should be able to splice the lights into the wire for the backup lights then splice it off to go to the switch. When they're spliced into the backup lights its like having them on a switch cause only power goes to the lights when it's in revers. Try hooking them up to the back up lights first to make sure the fuse can handle the amps drawn than go from there.
---------- Post added at 01:40 PM ---------- Previous post was at 01:38 PM ----------
The diagram is showing you splicing then to the brake lights which isn't what you're trying to achieve here you'll have to take the tail light off and follow the wire for the reverse lights and splice into it for power then run the ground wire either to the frame or another grounding wire to splice into.
aka grumpy car stereo guy
lovely diagram. haha. if you take a spdt relay you can wire it to make it work. connect 85 to the switch, the 87a to reverse, connect 30 to the lights, connect87 to constant and 86 to ground
Steve-O
Steve-O
Sumter, SC
your diagram is "before"
here is the "after"
thats f-ing hilarious!!!!!!! ive been laughing at that for the last hour.
what the hell are these numbers?!?!?! are those the wires to the tail lights? do you have an actual wiring diagram with all that on it?
SonnyAK
Anchorage, AK
Probably need to slide your seat forward a bit too...Looks like you're on your tippy toes, and you might lose good throttle control when you're in the really rough stuff!! :driver:
You need a bigger smile too!! :) Don't look so serious when you're rockin your Raptor like that!!
Hockster
My 45ft Bluewater Party
Winchester, Va
If it were me I wouldn't tie into the taillights. I have mine hooked to the trailer plug and if you want to run power to it for the ability to turn on anytime just install a one-way diode to stop the power from feeding back into the plug
those numbers are standard on all automotive spdt relays. pick one up and you will see what i am talking about.
also, about diodes. they will work, but the higher the amperage, the bigger they get. i dont know what the current draw is, so you would have to check. relays (from what i have seen) seem to be more reliable. i have seen more diodes fail compared to relays, and some have allowed current to pass through when they are not supposed to be able to. i have seen fried equipment, but thats electronic stuff, not so much lights.
