FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor
FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor (http://www.fordraptorforum.com/forum.php)
-   Ford Raptor Lighting Modifications Forum [GEN 1] (http://www.fordraptorforum.com/f81/)
-   -   Question about wiring lights (http://www.fordraptorforum.com/f81/question-about-wiring-lights-26897/)
Steve-O 08-29-2013 01:59 PM
1 Attachment(s)
Ok, so heres my goal: I want to hook up a set of lights (specifically TMX's Blackhawk X1) so they automatically turn on when I put the truck in reverse. Sounds easy right? Here's the catch... I also want to be able to turn them on manually through the upfitter switches. I drew up a "wiring diagram" of how I think it'll work but I need someone that knows what the hell they're doing to verify it and if its wrong, tell me what i need to do.
pat'sRAPTOR 08-29-2013 02:40 PM
Depending on the size of the fuse for the back up lights you should be able to splice the lights into the wire for the backup lights then splice it off to go to the switch. When they're spliced into the backup lights its like having them on a switch cause only power goes to the lights when it's in revers. Try hooking them up to the back up lights first to make sure the fuse can handle the amps drawn than go from there.
---------- Post added at 01:40 PM ---------- Previous post was at 01:38 PM ----------
The diagram is showing you splicing then to the brake lights which isn't what you're trying to achieve here you'll have to take the tail light off and follow the wire for the reverse lights and splice into it for power then run the ground wire either to the frame or another grounding wire to splice into.
Steve-O 08-29-2013 03:01 PM
I'm a dumbass. I meant to write "reverse light wire" on that picture.
ESRaptor 08-29-2013 03:35 PM
You need to put on little weight and adjust your seat before your back goes bad... pat'sRAPTOR seems to be headed in the right direction, I have no other expertise to offer.
The Car Stereo Company 08-29-2013 04:13 PM
lovely diagram. haha. if you take a spdt relay you can wire it to make it work. connect 85 to the switch, the 87a to reverse, connect 30 to the lights, connect87 to constant and 86 to ground
BIRDMAN 08-29-2013 04:49 PM
1 Attachment(s)
your diagram is "before"
here is the "after"
Attachment 28130
Steve-O 08-29-2013 06:13 PM
Quote:
here is the "after"
Attachment 28130
thats f-ing hilarious!!!!!!! ive been laughing at that for the last hour.
Quote:
what the hell are these numbers?!?!?! are those the wires to the tail lights? do you have an actual wiring diagram with all that on it?
SonnyAK 08-29-2013 07:14 PM
Probably need to slide your seat forward a bit too...Looks like you're on your tippy toes, and you might lose good throttle control when you're in the really rough stuff!! :driver:
You need a bigger smile too!! :-) Don't look so serious when you're rockin your Raptor like that!!
Hockster 08-29-2013 07:17 PM
If it were me I wouldn't tie into the taillights. I have mine hooked to the trailer plug and if you want to run power to it for the ability to turn on anytime just install a one-way diode to stop the power from feeding back into the plug
The Car Stereo Company 08-29-2013 07:58 PM
Quote:
those numbers are standard on all automotive spdt relays. pick one up and you will see what i am talking about.
also, about diodes. they will work, but the higher the amperage, the bigger they get. i dont know what the current draw is, so you would have to check. relays (from what i have seen) seem to be more reliable. i have seen more diodes fail compared to relays, and some have allowed current to pass through when they are not supposed to be able to. i have seen fried equipment, but thats electronic stuff, not so much lights.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
SEO by vBSEO
vB.Sponsors
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Ad Management plugin by RedTyger
