Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Lighting Modifications Forum [GEN 1]
Projector HID lights
This is a discussion on Projector HID lights within the Ford Raptor Lighting Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Has anyone installed a set of projector lights? Not replacing the whole housing with recon or anything. Stock housing with ...
Sponsored By: KC HiLiTES
Old 01-30-2011, 01:15 PM   #1 (permalink)
whtrapta's Avatar
Ostrich Wrangler
Default Projector HID lights
Has anyone installed a set of projector lights? Not replacing the whole housing with recon or anything. Stock housing with projectors. Im thinking of buying these but IDK how it will look. Angel Eye Headlights | Projector Headlights | Bi-xenon HID Headlights
Just when you think your done modifying... your not.
whtrapta is offline   Reply With Quote
Old 01-30-2011, 03:17 PM   #2 (permalink)
BIRDMAN's Avatar
Administrator
You have to put your headlights in an oven or use a heat gun to split the lens off the headlight housing. it's a lot of work and you can screw it up easily if you scratch the lens or get any gooey silicone on the lens while you're taking them apart. not worth the hassle IMO
Help Support FRF - Become A FRF Supporting Member!
Get Your FRF Decals
Play slow pitch softball? Check out Softball Forum!
BIRDMAN is offline   Reply With Quote
Old 01-30-2011, 03:36 PM   #3 (permalink)
whtrapta's Avatar
Ostrich Wrangler
Do you just have regular HIDs?
Old 03-17-2011, 02:35 PM   #4 (permalink)
CineSLR's Avatar
Roaming Shutterbug
There is a company here (in New Orleans) that does retrofits that I will be using to do my truck. If your interested I could see if they are interested in doing a group buy...? They do everything from Q45 Projectors, Custom Painting, ELWire to strobes to whatever you can dream up!
I'm going to be going with a single BiXenon (probably TSX projector) with a black bezel and strobes (off road/parade use only!).
My business partner did some photo work for them a year ago or so...
http://www.flickr.com/photos/syf0n/s...7605262196090/
CineSLR is offline   Reply With Quote
Old 03-17-2011, 02:40 PM   #5 (permalink)
CineSLR's Avatar
Roaming Shutterbug
That said, if your up to the task I would go for it and do it yourself. You will save a lot of money if you do it yourself...
Old 03-17-2011, 02:45 PM   #6 (permalink)
trolls56's Avatar
advanced automotive concepts - a set on Flickr
I'd be interest let us know what all you find out.
trolls56 is offline   Reply With Quote
Old 03-24-2011, 08:06 PM   #7 (permalink)
ShiftyCapone's Avatar
Very interested....Keep us posted.
ShiftyCapone is offline   Reply With Quote
Old 03-24-2011, 10:27 PM   #8 (permalink)
I am considering doing this myself, the only issue I have it with adjusting the headlights later on. Even with some smaller loads in the bed I need to move the headlights up quite a bit so you need to be able to both seal up around the back of the projectors and maintain flexibility so as not to break the seal. Could always mount the projector to the stock reflector but then how do you maintain flexibility in the back for load adjustments...
Spider-One is offline   Reply With Quote
Old 04-02-2011, 09:41 AM   #9 (permalink)
CineSLR's Avatar
Roaming Shutterbug
Dont keep the wire taught and use a rubber grommets is what I would do. Maybe someone with more experience can chime in.
Old 04-02-2011, 12:44 PM   #10 (permalink)
whtrapta's Avatar
Ostrich Wrangler
IDK my last vehicle you could adjust the light height from inside.
Tags
hid, lights, projector
HID Xenon Projector Fog Lights IRONMAN Ford Raptor Lighting Modifications Forum [GEN 1] 46 03-22-2013 11:15 AM
PIAA Fog Lights danmpe Ford Raptor Lighting Modifications Forum [GEN 1] 15 03-02-2012 05:31 PM
CCFL projector lights Sgt Soynut Ford Raptor Lighting Modifications Forum [GEN 1] 41 06-08-2011 03:56 PM
Mood lights dbmaster Ford Raptor Interior Modifications Forum [GEN 1] 31 04-11-2011 07:31 PM
lights warrior Ford Raptor Lighting Modifications Forum [GEN 1] 2 01-19-2011 11:02 AM
