I just jammed a 41" lightbar into a 40" hole. And i ripped out my radiator air deflectors in the process. Lets see yukons instead
I did my install so long ago and posted pics already. you'd have to really search to find it. Lol....
I used the supplied M&R bracket. Nothing fancy but an inexpensive headwear L bracket with a slot on one side and a hole on the other.
I upgraded the bolt and nut they mount to the truck with a 1/4" or 3/8" stainless carriage bolt, lock washer and nut. The hole in the frame has a plastic nut on the bottom side. This gives out about your second raptor run. At least mine did. Lol... I pushed the plastic nut out and inserted the carriage bolt from the bottom into the square hole. It really worked out well.
Yukon Joe
www.RUNRAPTORRUN.com
