Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Lighting Modifications Forum [GEN 1]
Low beams not functioning
This is a discussion on Low beams not functioning within the Ford Raptor Lighting Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
So I ordered some retrofit headlights for my 2012 F150, which I installed on my own and they worked fine ...
Sponsored By: KC HiLiTES
Old 12-22-2017, 01:00 AM   #1 (permalink)
Junior Member
Default Low beams not functioning
So I ordered some retrofit headlights for my 2012 F150, which I installed on my own and they worked fine except for the LED strip I didn't trust myself to install. I waited on the lights to start a road tip, and when i got to a spot where I found what looked like a decent shop, I thought I would just have it done since it should be quick. While they went about it in a dumb way since they weren't aware that headlights could come out (???), they did a legit job getting the LEDs to work. Unfortunately, now the low beam headlights dont work. The headlights and the LEDs are entirely different power sources, so its hard to understand how one effected the other. We checked all relevant fuses, and everything seemed fine. I could get the low beams to randomly work, but were prone to just go out while driving... and then I'd be unable to immediately get them to work. It was basically entirely random when they would choose to work.
Before headlight install :
• Low beams work
• High beams work
• LEDs not connected
• Turn signals work, but random hyperblink on the right side (no resistor installed for LED taillights, but the recons shouldnt need them as far as I understand)
After
• Parking lights work
• LEDs work
• Low beams dont work
• High beams work (and when going from low to high, the low beams show for a split second and then turn off)
• Right turn signal goes off sometimes when turning on/off high beams
• Right turn signal still hyperblinks occasionally
I had a mobile repair guy come out and run diagnostics (attached) Seems like some control module since all fuses check out. BCM?
Any help is greatly appreciated– this has put the road trip on hold as a lot of driving is planned to happen at night.
** NO clue why the attachment is being shown upside-down, its right side up on my computer...
onnex is offline   Reply With Quote
Old 12-22-2017, 01:04 PM   #2 (permalink)
4x4TruckLEDs.com's Avatar
Are you running LED or HID headlights? If so the first thing I'd do is try adding a set of CANBUS Anti-Flicker adapters in there... if you're not running HID/LED headlights well then I'm not quite sure where to even begin
CANbus Anti-Flicker Resistor - 4x4TruckLEDs.com
Adam
Use coupon code RAPTORFORUM at checkout for 10% off eligible items in our store
LED HEADLIGHTS, FOG LIGHTS, LIGHTBARS, BULBS & MORE
Like us on FaceBook - Follow us on Instagram - www.4x4TruckLEDs.com
4x4TruckLEDs.com is online now   Reply With Quote
Tags
bcm, headlights, lighting, retrofit, troublshooting
High beams stuck on memberthttime92 Ford Raptor Problems and Questions Forum 16 01-07-2015 07:01 PM
2014 Raptor windshield washer not functioning Sgtmac26 Ford SVT Raptor General Discussions [GEN 1] 7 11-21-2014 08:15 PM
WTB: Used, ugly but functioning Whelen Micro Pioneer shooterAMG Want to Buy 0 10-06-2014 04:08 PM
HID Install High Beams On Kornfed Ford Raptor Lighting Modifications Forum [GEN 1] 3 02-04-2014 10:12 AM
High Beams and running lights IKillDeer Ford Raptor Lighting Modifications Forum [GEN 1] 5 12-17-2012 05:41 PM
