LEDs on third brake light
svt_ivan
Dallas, TX
When do the leds on the third brake light turn on? Are those my brake lights or are they suppose to be on all the time when all my other lights are on? I have a feeling they might be no good.
svt_ivan
svt_ivan
Dallas, TX
The LED's turn on when your lights are on. They also get brighter when you step on the brake. What do you mean by "no good"?
I guess that's what I needed to know. They're not lighting up whatsoever and I just noticed it today.
sidelock
FYI
FYI:
Replaced entire 3rd brake unit last July on my "13 SCREW. One LED gone. Just had dealer order another one. This time it was a different LED bulb gone. No charge - warranty. Looks like it's a weak manufacturer part.
svt_ivan
svt_ivan
Dallas, TX
FYI:
That's awesome. The thing is I have mine tinted, do you think i'll have any problem with the dealership not wanting to warranty out due to that?
SilentShooter
Siesta Key, FL
Just had my unit replace this week. The LED's burned out. Actually noticed it because there was a big burn mark inside the lens. Ford must have Recon making these for them
WRCRaptor
Great Lakes
Replaced mine out to warranty for $150.00 for same issue no LEDs. Also no signs of water damage which is a common problem.
RangerRob
Ramona, CA
Might be a good idea to check the connector and plug on the back of the light. I was having an issue with my LEDs not coming on a few months back. I pull the light and discovered that two of the metal blades inside the connector weren't making contact, so the LEDs weren't getting power. Just throwing it out there that it weren't hurt to check the connectors before a replacing the whole light
-Rob
svt_ivan
svt_ivan
Dallas, TX
-Rob
Yeah, i guess should check the connectors before trying to get it replaced under warranty. Thanks for the heads up.
