Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Dremel with a cut off wheel or sanding drum, die grinder, all will work great, all I did was draw out the cut lines, drilled a hole in each corner, to keep the rounded edge, and cut my straights, nice working with glass cuts easy.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
