Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Lighting Modifications Forum [GEN 1]
Has anyone run the Baja Designs Arc Bar?
This is a discussion on Has anyone run the Baja Designs Arc Bar? within the Ford Raptor Lighting Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Just ordered a 30" Baja Designs arc bar for a custom SVC bumper they are doing for me. Was looking ...
Like Tree2Likes
  • 1 Post By Baja Designs
  • 1 Post By PropDr
Sponsored By: KC HiLiTES
Old 07-08-2014, 07:28 PM   #1 (permalink)
Default Has anyone run the Baja Designs Arc Bar?
Just ordered a 30" Baja Designs arc bar for a custom SVC bumper they are doing for me. Was looking to see who has experience with them. Looks like the Baja bars have a High/Low and flash sequence you can toggle. When wiring them for the raptor is it a PIA to wire this functionality?
So the bumper will have four KC 6" Pro Sport HID's (2 Spot, 2 Spread) on the top and then the 30" Baja Arc in the center and an led cube in a fog pattern in each corner triangle.
2014 Terrain SCREW -
It's turning into a Mutt..
SilentShooter is offline   Reply With Quote
Old 07-09-2014, 01:42 PM   #2 (permalink)
Baja Designs's Avatar
The wiring is quite simple, you just have run a ground from the switch and the other leg from the momentary switch to either a chassis ground our battery ground. Shoot our tech support department a call and they can walk you through it. Let me know if you need anything else, thanks - Christian
SilentShooter likes this.
www.bajadesigns.com
-Bailey, Baja Designs
Baja Designs is offline   Reply With Quote
Old 07-09-2014, 02:39 PM   #3 (permalink)
PropDr's Avatar
My Truck
PropDr is offline   Reply With Quote
Old 07-09-2014, 10:22 PM   #4 (permalink)
Do you guys have cube lights with a pattern that will work well for fog light duty?
Old 07-10-2014, 12:46 PM   #5 (permalink)
Check out the Baja Designs Squadron LED, they are available in four patterns as well as amber ( great for fog). And we offer the kit linked above, to mount two in each fog pocket let me know if you need anything else, thanks - Christian
www.bajadesigns.com
New from baja designs!!! Baja Designs Ford Raptor Lighting Modifications Forum [GEN 1] 18 05-13-2014 04:56 PM
Baja Designs 15'' ONX Blowout! Baja Designs Ford Raptor Lighting Modifications Forum [GEN 1] 3 04-30-2014 04:48 PM
Baja Designs HID Special! AlternativeOffroad Alternative Offroad 7 04-25-2013 01:17 PM
Baja Designs Lights! Outlaw Offroad Outlaw Offroad 0 02-06-2013 06:14 PM
Please Welcome Baja Designs to FRF! BIRDMAN Baja Designs 20 11-05-2012 08:21 PM
