Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Lighting Modifications Forum [GEN 1]
Ford Racing Light Bar KC PODS
This is a discussion on Ford Racing Light Bar KC PODS within the Ford Raptor Lighting Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
HI I waiting for delivery of my 2014 Raptor and looking to put the ford racing light bar on the ...
Like Tree1Likes
Sponsored By: KC HiLiTES
Old 12-31-2013, 10:55 PM   #1 (permalink)
Junior Member
Default Ford Racing Light Bar KC PODS
HI
I waiting for delivery of my 2014 Raptor and looking to put the ford racing light bar on the front do the KC PODs carbon fibre fit without hitting the grill on the top and also on the bottom.
http://www.kchilites.com/wp-content/.../9635-Data.pdf
Thanks for any help
or is there a better option a good light bar
Thanks Andrew
Andrew22 is offline   Reply With Quote
Old 12-31-2013, 11:36 PM   #2 (permalink)
I have the kc light bar on mine. The one big advantage I like over the ford bar is that there is a brace on the kc bar that fastens to the license plate holes. It makes it much less likely to vibrate.
Az Scooter is offline   Reply With Quote
Old 01-01-2014, 01:11 AM   #3 (permalink)
Junior Member
I have had a look at the KC light bar only issue is its a fair bit higher the the ford racing bar and will obstruct the the forward facing camera
Old 01-01-2014, 01:35 AM   #4 (permalink)
All The Way's Avatar
So does the ford bar
All The Way is offline   Reply With Quote
Old 01-01-2014, 10:13 AM   #5 (permalink)
They both will block, especially with round lights. Mine are 7.5" and block the camera, but really, they do not block so much that it is totally unusable, in my opinion. I also really don't depend on the front camera that much, so...
Old 01-01-2014, 05:09 PM   #6 (permalink)
wolfnnc's Avatar
The Racing bar does not stick out that far, I ran KC Halogens w/ no problem at all. I do
think you will run into issues w/ the KC PODs, since they are 7.55" from front to back, and 4.5" from mounting point to back of light.
I have an SDHQ Bumper, and was looking at running the PODs since they are amazing, but the measurements were not adding up...and I would hit...keep in mind my bumper sticks out much further then the Racing Bar, and barely fit the Vision-X XPs which are 5.55" from front to back.
ICON 3.0 Coil-overs & Shocks / ICON UCA / SDHQ 4 Light Bumper / KC Aux Lights / RPG Tie Rods / RPG Stage 2 / Fuel Krank Wheels / Stainless Works Lightning Exhaust / Black Matte Hood / Hennessey CAI + 93 tune / Lowrance Elite-5M Baja / Outlaw Raptor GPS Mount
wolfnnc is offline   Reply With Quote
Old 01-01-2014, 08:47 PM   #7 (permalink)
JGov's Avatar
Originally Posted by Andrew22 View Post
HI
Thanks for any help
Thanks Andrew
Hey I have a black kc light bar for sale it's basically new I mounted it to the truck fora very short time and never mounted lights to it for sale for 200 plus shipping from Vegas
JGov is offline   Reply With Quote
Old 01-02-2014, 03:45 AM   #8 (permalink)
BAJASVT's Avatar
The N-Fab light bar is a little higher, so it might allow more room for the depth of the KC Pods because it will get them above the plastic bumper. On the down side, it will probably block the front camera more. IMO the front camera is pretty useless unless you get something aftermarket to turn it on/off at will.
The attached photo (black truck) is a KC light bar with Hella Rallye 4000 Compacts. They look pretty close to the plastic bumper.
Sorry I don't know the answer to your question, but hopefully this helps a little.
BAJASVT is offline   Reply With Quote
Old 01-02-2014, 08:04 AM   #9 (permalink)
G & P Racing's Avatar
You are on the right track to a killer light setup. The KC Carbon Pods are badass and put out a ton of light. Since you are starting w this as your light of choice, $$$, you won't mind just a little extra effort and $ to make the light bar work. Sounds like you are not looking for a complete bumper but want to keep the stock setup and just run a add on bar. Go w a bar w an extra brace, for when you start bouncing around, and pick up some pre fabbed tabs from Kartek, have a shop weld them on the front side of the light bar across from the standard mounts. This should give you the clearance you need. Cut off the old tabs, powder coat it all black, there ya go. Or call CONNOR at Outlaw, Marvin his fab guy could whip a custom bar out easy. Those KC pods are worth the effort! Check out the new Herbst Racing setup, they have switched to KC Pods, 7 across the top, 2 on the A pillar, 4 up front.....blinding!, good luck and have fun w your mod.
MTUH3 likes this.
We are grateful to have Outlaw Raptor http://www.outlawraptor.com/home.aspx and Icon http://www.iconvehicledynamics.com/s...b-Ford-Raptor/ involved in our race program. We look forward to a lasting relationship.
G & P Racing is offline   Reply With Quote
Old 01-02-2014, 08:41 AM   #10 (permalink)
MTUH3's Avatar
I have the KC Bar on my truck, same as the Ford Racing bar.
Works great, now I just need to upgrade my lights. I want to run some KC HIDs on the bar and some LED bars down low, center of bumper and corners. At least that is the thought / plan right now.
Carl - Plymouth, MI
2011 Super Crew - MRT Exhaust, Front Icon 3.0 Coilover, Rear Fox 3.0 shocks 2.0 bumps, Hellwig rear sway bar, SVC Upper Control Arms
https://www.facebook.com/RogueWaveIndustries
MTUH3 is offline   Reply With Quote
Ford Racing Light Bar Installed! Gus00SVTL Ford Raptor Lighting Modifications Forum [GEN 1] 27 05-06-2013 09:25 AM
FS: Ford Racing Light Bar (Black) $200 dinoone Garage Sale 7 02-13-2012 06:47 PM
ford racing or kc light bar uaq69 Ford Raptor Exterior Modifications Forum [GEN 1] 3 02-06-2012 09:23 PM
Looking for Ford Racing Light Bar with Lights IARaptor Want to Buy 12 08-24-2011 01:43 PM
Looking for ford racing light bar jesse Want to Buy 3 06-25-2011 01:58 PM
