Jhollowell
Hey guys. I’m attempting my first HID retrofit and ran into a little snag. First off the build is using 09-14 OEM halogen housings and i went with the mini H1 kit from the retrofit source. My issue is when i try to mount the projector in the reflector the threads of the projector don’t protrude through the back side so i can’t get the nut on or the adapter plate. Is there an extension or some kind of adapter i can get to make the projector longer? Or do i have to grind the back of the reflector housing to make it shorter?
