finished with aftermarket switches
rap67
SE michigan and Arkansas
Finally done with the spod switch bank and new switches.
I started with the OEM up fitters, then added another 4 up fitters in the dash, then got the spod and removed the additional 4 upfitters.
I didn't like the spod being powered by an always on circuit nor did i like the switch lighting. so I got rockers with power on indictor lights and switch ID lights.
In addition I installed a 200 amp automotive relay which closes and opens with an ignition controlled power source so the lights and compressor, controlled by these switches, will only work with the ignition on.
I'm very happy with the final result...
thanks to Rookie for the ride in his truck which is where i first saw the Spod switch bank!
Rookie
Fort Wayne, IN
Glad you like them Marc. They turned out nice! I like the dual led setup.
freedommotorsports.us
Phone: 260-444-7503
Email: [email protected]
