Finally quality LED tail lights!
dawing
I new the minute I opened the box and saw how well the product was packed that I was dealing with qulality. The electronics are all Philips which are amoung the best in LED lighting. They work fine with the Ford software.Fit and finish are comparible to the OEM tails. I decided to mount one at a time and drive around for a day to be sure. I took day light pictures which I consider a better test to judge intensity. I ordered them here and they arrived in a few days :
09-10 Ford F150 Styleside LED Tail Lights - Red Smoke (Pair)
They come in different styles including smoked.One member found them for less on ebay.I had no luck.
RaptorScrew
Oronoco, MN
I like the appearance of those! Can you make the bottom two pictures bigger?
Nice find. Are the Reverse LED as well?
dawing
led
I odered sound off signal 1400 lumen work lights for the back.The backup uses the existing bulb. Have truoble with the pics.Try leaning closer to the screen.....
6.2
Banned
Canada
I like this guy hahaha
And those do look awesome!!
If you guys want you can replace the stock reverse bulb with a 120 white LED reverse replacement bulb. What bulb type is the stock, I'll see if my buddy has some.
It would totally complete any LED tails. Bright as **** to.
dawing
If you go to bright on reverse it will wash out your rear camera view.My 1400 lumen backup lights will be switched.
6.2
Banned
Canada
They're not that bright lol. They give a nice white glow on the ground and any upright objects is say in a 10 foot area.
I'll try and take pics. I'd imagine it would be perfect for the camera to see in the dark
