Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Lighting Modifications Forum [GEN 1]
DPDT Relay for Rigid 20 Lightbar to Flash or stay Solid
This is a discussion on DPDT Relay for Rigid 20 Lightbar to Flash or stay Solid within the Ford Raptor Lighting Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
I am about to install a Rigid E Series 20 on the front lower and a pair of Dually flush ...
Like Tree2Likes
  • 1 Post By farmerdave
Sponsored By: KC HiLiTES
Old 03-05-2013, 09:11 AM   #1 (permalink)
Junior Member
Default DPDT Relay for Rigid 20 Lightbar to Flash or stay Solid
I am about to install a Rigid E Series 20 on the front lower and a pair of Dually flush mounts on the rear bumper. I plan on utilizing Rigid's flash modules for the LED's (3 AMP for the rear, part # 40312 and 6 AMP for the front 20, Part # 40612).
I want to be able to have the Lights stay solid for standard applications, or flash when needed...normally, with a flasher module when you flip the switch (upfitter) it will only flash. Im looking to have the option of utilizing all 4 Upfitters in the fiollowing manner:
#1 Front LED Light Bar ON
#2 Front LED Light Bar Flashing
#3 Rear Dually's ON
#4 Rear Dually's Flashing
My initial conversation with the fella from Alternative Off Road had both of us in agreement that all I would have to do is "T" the hot wire from the LED's sending one wire direct to Upfitter #1 and the second wire from the "T" to the flash module, then to Upfitter #2.
This should work, but it doesnt resolve an issue if someone were to flip both Upfitters #1 and #2 on of causing an issue. (would it ?)
A buddy of mine suggested using a DPDT relay....while I understand the concept...I figured Id come on here (first post) to ask the resident "experts" to help a brother out. Thank you !
farmerdave is offline   Reply With Quote
Old 03-05-2013, 09:53 AM   #2 (permalink)
pat'sRAPTOR's Avatar
I looked into the flasher modules from rigid as well but I was under the impression that you could change the modes on it to flash different ways or stay solid. Guess I thought wrong. Did you try contacting rigid to see if they had a solution? I'm sure you aren't the only one that's wanted this I'd like to know for sure cause this would be a sweet feature!
pat'sRAPTOR is offline   Reply With Quote
Old 03-05-2013, 11:35 AM   #3 (permalink)
Junior Member
you were correct....u can change to any of the 7 patterns, or stay solid....once u tie off the hot lead, thats the mode it will stay on....if you want to change the pattern, you have to pull the hot wire and "tap it to to the positive" until u find the pattern you want.
Basically u have to make the choice initially and stick with it...u cant switch between the two....hence my cry for help.
Thanks.
Old 03-06-2013, 08:05 AM   #4 (permalink)
Junior Member
Solved !
Sooooo...after a more extensive conversation with the guys at Rigid, we figured out that the wire from the flasher unit that is used to change the patterns...can be run directly to an upfitter switch...say #2 (upfitter #1 would have the hot wire to it to power the flasher unit).
#2 would act like a momentary switch, thereby, allowing you to cycle thru the multiple patterns including solid, just by toggling #2 on and off.
There is no concern of having both #1 and #2 "hot" at the same time as the flasher is set up to accept a "hot flash" to change the pattern but then closes the circuit.
Boom...thanks to Rigid and Alternative Offroad for helping me work this out.
Old 03-09-2013, 06:16 PM   #5 (permalink)
Junior Member
Glad you worked it out -- post some quick videos of the rigid in action once you get it set up. I think this would be a sweet mod as an emergency signal or hazard light.
jadanf is offline   Reply With Quote
Old 07-21-2017, 01:10 PM   #6 (permalink)
The rigid flasher module does not have constant on as an option. My understanding is you wanted two switches: one to turn on and stay on and one to make them flash. If you want this you will require a 5 pin relay or T the power lead and put in line diodes to prevent the switches from competing.
U can add a third switch to the equation that acts as a momentary switch to change the flasher mode
The concept is here:
https://youtu.be/Lko2XrbSQaM
OBXRAPTOR17 is offline   Reply With Quote
Old 07-22-2017, 06:07 PM   #7 (permalink)
tomahawk's Avatar
this is why I love my light bars...they come with a wireless remote that I can not only change the color from white to amber but have strobe function at the push of a button no messing with the wires or anything and you can buy a wireless module if you already have a light bar and want it to strobe
tomahawk is offline   Reply With Quote
Tags
led, rigid, strobes, upfitter
Rigid 20" Lightbar & Duallys - Installation Instructions MagicMtnDan Ford Raptor Lighting Modifications Forum [GEN 1] 207 10-19-2017 08:33 AM
Extra Fuse & Relay CSX4350 Ford Raptor Problems and Questions Forum 9 05-11-2017 05:16 PM
Rigid 40" E-Series LED Lightbar AlternativeOffroad Garage Sale 13 03-02-2013 05:40 PM
Solid Fold or Bakflip F1 if I have BedExtender jlbeau Ford Raptor Exterior Modifications Forum [GEN 1] 5 12-03-2012 11:37 AM
Is Relay Needed??? Kraka Ford Raptor Lighting Modifications Forum [GEN 1] 2 06-30-2011 08:05 PM
